11Button : UART4
Button : UART4
12Slider : A2
Slider : A2
13Rotary : A5
Rotary : A5
14Re-Power
15Login
admin admin
16Setup Account
17License Key
Add License key sent to you:
18Add Data Collectors
19Add A2_Slider
#!/usr/bin/python3 import os import time import sys adc0 = open("/sys/bus/iio/devices/iio:device0/in_voltage2_raw", "r") devID = "A2_Slider" voltage = int(adc0.read()) print("metric:id=%s,n=Reading,vd=%0.1d,u=S" % (devID, voltage)) adc0.seek(0) time.sleep(1) adc0.close()
20Add A5_Rotation
#!/usr/bin/python3 import os import time import sys adc0 = open("/sys/bus/iio/devices/iio:device0/in_voltage4_raw", "r") devID = "A5_Rotation" voltage = int(adc0.read()) print("metric:id=%s,n=Reading,vd=%0.1d,u=S" % (devID, voltage)) adc0.seek(0) time.sleep(1) adc0.close()
Just in case someone else runs into this problem, if the wlan0 device is unrecognized, check that the PocketBeagle board pins are schmooshed down all the way.
