Macropad 4chord MIDI
Compose with just four chords using Adafruit's Macropad
The Macropad 4chord MIDI was built to make it easy to build melodies, harmonies, percussion and bass lines with a simple MIDI keypad. You can connect the Macropad to any studio recording software that accepts MIDI devices, such as GarageBand or Renoise.
In the "chord progression" mode, the root note is at the top left with the major (or minor) third and perfect fifth on the middle and right keys.
The "auto chord" mode allows you to play chords with the tap of a single key and modify them to be major, minor, augmented, diminished, or 7th chords within a progression.
In "melody" mode you can walk a highlighted scale, such as pentatonic, harmonic minor, blues minor, etc. Each note on the chromatic scale is pressable on the keypad, but only the notes in the scale are highlighted.
The "drum pad" mode allows you to hammer specified percussion instruments to create a rhythm. A standard drum kit and electronic kit layout is provided and
Installation is pretty simple - assemble a Adafruit Macropad, then follow the installation instructions in the GitHub repository's README. You can be up and running in minutes!
The Macropad needs to be connected to a digital audio workstation (DAW) or other MIDI software in order to receive the controls & keys. GarageBand, LMMS, or Ableton Live! should be able to do the job.
  • Now Supports CircuitPython 9
    DeckerEgo2 days ago 0 comments
    The MacroPad 4chord MIDI has just been updated to support CircuitPython 9.x and the latest Adafruit core libraries. Test away and let me know if you see any issues!
    The next demo will be with either Bitwig or openDAW.
  • Full Demo of 4chord MIDI + Hookpad
    DeckerEgo05/21/2023 at 14:27 0 comments
    I'm going to start narrating my 4chord MIDI demos, starting with Hooktheory's Hookpad. It's an interesting webapp that's not necessarily a DAW but instead acts as a musical "sketchpad," where percussion & basslines are automagically added so you can focus on harmony and melody. You can export works as sheet music, lead sheets, or MIDI files - so it's a fantastic way to quickly build a song or a track before you perform it.
    This demo shows how the autochord feature of the 4chord MIDI can really help with the "Creep" chord progression, since it is an atypical I / III / IV / iv progression.
  • A Song Written in Collaboration with Google Bard
    DeckerEgo05/07/2023 at 21:09 0 comments
    I attempted to write a song alongside Google Bard. I asked Bard to define the harmony, melody, drum pattern, even lyrics... it appears to get confused pretty darn quickly. But hey - it's something that we could test in less than ten minutes!
    See the YouTube video for my conversation with Bard and the results. They will disappoint.
    Also note that there was a rolling shutter issue when filming the Macropad, so the OLED screen does flicker. Light sensitive viewers be aware before launching
  • Introducing the Auto Chord Mode
    DeckerEgo05/07/2023 at 21:06 0 comments
    A new mode has been added! What was previously considered to be the "harmony" mode has been split into two: the "triad mode" and the "autochord" mode.
    The auto chord mode binds an entire chord to a single key, allowing you to easily navigate through a progress. However, taking some inspiration from the Omnichord System 2, you can press adjacent keys to play the minor and 7th chords. Using a combination of keys you can also play augmented, diminished, major 7th, and minor 7th chords.
    This allows you to play arpeggiated chords easily in "triad" mode, but also play variations of the chords within a progression using autochords.
  • Walk the Scales with the Melody Screen
    DeckerEgo03/29/2023 at 01:37 0 comments
    Up to now you have been able to build harmonies using four-chord progressions, or build a rhythm track using the drum pad screen. Now you can build melodies using the "scale" screen!
    Choose Minor Pentatonic, Major Blues, Harmonic Minor - whatever scale you so desire and pick your key + octave. All twelve chromatic notes are pressable (starting with your root note), however only the notes in your scale are highlighted. This way you can hammer out a pentatonic scale to accompany your chords, and add some transition notes along the way if you like.
    With this update you have all the basics you need to build a track. You can lay down kick/snare/toms, then add a harmony plus a bass line with the four-chord progression screen, then hammer out a melody on a complementary scale. Perfect for when something is stuck in your head and you need to get it in a DAW before you forget it.
  • Creating a Track in Renoise
    DeckerEgo03/29/2023 at 01:31 0 comments
    A demo of creating a track in Renoise, this time showing of the Macropad 4chord MIDI's new melody feature:
  • Demo Video - Build a Song in 5 Minutes
    DeckerEgo03/30/2022 at 01:35 0 comments
    A demo video showing how to build some loops & backing tracks with GarageBand and the MacroPad 4chord MIDI:
  • Drum Pads, MIDI Controls, and Pitch Bending
    DeckerEgo03/28/2022 at 01:31 0 comments
    The Macropad 4chord MIDI has been updated with a ton o' stuff, including:
    - Drum pads!
    - Individually set MIDI controls
    - The "Take On Me" chorus progression :)
    - Pitch bending when playing notes
    Latest version is listed on the GitHub page!
View all 8 project logs
davedarko wrote 03/30/2023 at 09:18 point
need to try this with #LoKiPAD , this is awesome :)
