Hackaday.io Hackaday.io
Sign up Log in
Z80 microcomputer
This microcomputer system combines a vintage Z80 microprocessor with a modern ATMEGA328P microcontroller.
nigelhunternigel.hunter
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
10.8k views
3 comments
131 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 3
View Gallery
10.8k
3
131
63
Team (1)
  • nigelhunternigel.hunter
Join this project's team
Z80 ATMEGA 328P BBCBASIC
Related lists
Z80 computers
Computers using or emulating z80
Z80
Projects involving Z80 microprocessors
This project was created on 02/24/2014 and last updated a year ago.
Description
A vintage Z80 CPU forms the core of the system. However, it uses a modern ATMEGA328P microcontroller (running the Arduino boot loader and my own custom Z80/ATMEGA interface routines) to provide most of the I/O capability.
An additional ATMEGA328P is used to provide a composite video output (using Grant Searle’s design) which drives a video converter so that a VGA monitor can be used.
The Z80 runs a custom BIOS which fits into a very small portion of the 8K EEPROM. The remainder of the memory map is occupied by 56KB of RAM.
Various I/O calls have been implemented including writing to the video interface and reading characters from a serial terminal. I’m still deciding how I’ll interface the system to a keyboard.
The Z80 BIOS provides access to the SD card reader via the ATMEGA microcontroller.
NASCOM 8K BASIC can be loaded from the SD card but my preference is the superior Z80 version of BBC BASIC, which was created using a series of source files kindly provided by the author.
Project Logs
Collapse
  • PS2 keyboard driver module
    nigel.hunter • 05/09/2014 at 17:18 • 0 comments
    I found one of these on eBay the other day
    http://www.ebay.co.uk/itm/121126647632?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
    Just connect your PS2 keyboard to it and then you get serial and parallel outputs related to the keys that you press.  I'd thought about building my own interface, which would be pretty simple to do, but this seems like it will do the job.
    Less than £3 delivered.  Ordered.
    I'll connect it to my Arduino Uno first to see what it sends out.
  • Bluetooth keyboard
    nigel.hunter • 04/30/2014 at 17:19 • 0 comments
    I bought one of those nice cheap Bluetooth keyboards and was planning on using it with an HC-05 Bluetooth module.  However, although the keyboard works fine with other things, the HC-05 does not work with keyboards, regardless of what the seller claimed.
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
John Smith wrote 07/31/2020 at 06:46 • point
Hi Nigel. Could you please share schematics?
Jonathan wrote 08/31/2017 at 12:35 • point
Am currently looking to add an Arduino Nano to my Z80 SBC to provide I2C and SPI interfaces - would love to see the files for this project if they're available?
Dr PEKER wrote 04/11/2017 at 02:03 • point
where is the files?
Fully working laptop with stereo speakers.
Project Owner Contributor
ZX Spectrum 128k micro laptop.
sziklaiSziklai
(Yet Another) Yet Another Z80 computer. This is built with parts I found-have so don't expect much.
(YA)YAZ80
olsenolsen
Minimal Z80 computer with CP/M
CP/M on a minimal Z80 Computer
doctor-voltDoctor Volt
Another Z80 single-board computer.
Z80 Single-board computer (with AVR controller)
scottScott
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Z80 microcomputer", please tell us the reason.
Send message
Remove Member
