1Step 1
The assembly is pretty straightforward - order the PCBs (which can be found linked at the Blogspot page, they are Eagle CAD files),
2Step 2
order the parts needed for PCBs,
3Step 3
and simply solder it all together according to schematics! Node circuit board is populated with predominantly surface mount components therefore you should heat gun (if available) or an oven/skillet/whatever can heat things (not microwave).
panovvv
