The M5Stack used in this project can be programmed visually.
If you are using M5Stack for the first time, please follow the documentation on the official website to download M5burner and install the UIFlow firmware.
Then set up Wi-Fi to connect from M5Stack and UIFlow.
If you do not have Wi-Fi, there is also a desktop version of UIFlow that allows USB connection.
Using UIFlow is very convenient because the UI of the M5Stack can be created intuitively with GUI.
AIRPOCKET
