Initializing the M5Stack
A project log for M5Stack Color Maker
With this device, you can copy the color of an object or create a new color with your imagination.
airpocketAIRPOCKET • 10/08/2021 at 04:28•0 Comments
The M5Stack used in this project can be programmed visually.
If you are using M5Stack for the first time, please follow the documentation on the official website to download M5burner and install the UIFlow firmware.
Then set up Wi-Fi to connect from M5Stack and UIFlow.
If you do not have Wi-Fi, there is also a desktop version of UIFlow that allows USB connection.
Using UIFlow is very convenient because the UI of the M5Stack can be created intuitively with GUI.
