If you want exquisite metal items, follow this recipe below ...
Start by dreaming up a beautiful thing.
Then take some carbon fibers or graphite fibers. Create whatever you want with it.
These magic fibers will be the geometric precursor to your item. They will also guarantee superb endurance.
That carbon thing's gonna be metal if you throw it in a plating bath. Now the miracles will begin! :)
Thank you! I will do my best to spread the word so this technique is not lost to history. I've been hoping you would reveal it since last year, but only just now found this page since you never updated the original metal bone project.
So it's not simply metal foam, but metal matrix carbon fiber. Very interesting, particularly since it provides a heat-tolerant alternative to epoxy matrix. Perhaps this is the solution Elon needed for his Starship, when carbon ended up needing so much heat shielding that it lost most of its weight advantage over steel.
Much work to be done measuring stiffness and strength and density to see how things made this way compare to solid aluminum and traditional carbon fiber with epoxy. I'd also like to see if I can include chunks of solid metal in the plating substrate to create areas for post-process machining. Not sure if they will bond strongly enough.
The biggest problem I can think of is galvanic corrosion. If the metal is abraded, revealing some carbon surfaces, it will likely start eating away at itself if there's much moisture in the air. Titanium would be less reactive with carbon, but seems difficult to electroplate from quick research. If it is an insurmountable problem, there are still options such as using metal wool as the fiber base. And of course keeping the object painted or periodically re-plating would help to retard the corrosion.
