Globe.STL
Thicker walls (~2mm thick), takes a bit longer and uses more filament but slightly better diffusion and probably longer glow if glow in the dark filament is used. Print right-side up at 0.25mm layer height.
Standard Tesselated Geometry -
1001.45 kB -
10/07/2021 at 13:44
