Hackaday.io Hackaday.io
Sign up Log in
vacuum
my progress with vacuum systems experiments
3drobert3drobert
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2 comments
1 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 12
    • View all
  • Instructions 0
  • Discussion 2
View Gallery
748
2
1
1
Team (1)
  • 3drobert3drobert
Join this project's team
MISC
ongoing project
High Vacuum
This project was created on 10/11/2021 and last updated 2 years ago.
Description
Documenting attempts and achievements to have my high vacuum system
Project Logs
Collapse
  • magnetron machining progress
    3drobert • 06/17/2024 at 22:15 • 0 comments
  • new magnetron design
    3drobert • 06/13/2024 at 07:31 • 0 comments
  • magnetron design progress
    3drobert • 06/06/2024 at 09:01 • 0 comments
  • new final setup
    3drobert • 05/23/2024 at 11:13 • 0 comments
  • more purchases
    3drobert • 05/19/2024 at 21:47 • 0 comments
    new purchases:
    8 copper non-resistive spark plugs
    Loctite Hysol 1C / Torr Seal Vacuum Epoxy Resin Sealant
    main chamber with 3x ISO160 outputs (+ 3x ISO160 centering rings)
    1x ISO160 viewport
    1x ISO160 blind plate
    1x ISO160 to KF25
    1x six way KF25
    1x KF25 vent valve
    5x KF25 blind plates
    2x KF25 valves (I only had one)
    2x KF25 bellows (300mm)
    1x Pfeiffer PKR251 (KF40) + KF40 to KF25 reducer + KF40 clamp + KF40 centering ring with screen
    1x 3 way KF25
    1x KF10 blind plate (+ clamp, centering ring...) (for turbo vent output port)
    more KF25 clamps (+ centering rings SS304)
    more ISO clamps
  • vacuum system schema
    3drobert • 12/14/2022 at 18:19 • 0 comments
  • firsts connections for turbomolecular pump
    3drobert • 12/14/2022 at 15:41 • 0 comments
  • waiting for this firsts connections
    3drobert • 11/18/2022 at 18:00 • 0 comments
  • TPH-170 turbo pump + TCP-380 controller
    3drobert • 11/17/2022 at 19:35 • 0 comments
    Startup test for Pfeiffer TPH-170 turbo pump with TCP-380 controller
  • TCP 380 controller
    3drobert • 05/11/2022 at 05:55 • 0 comments
View all 12 project logs
Log In/Sign up to comment
Sign up with Github
OR
3drobert wrote 12/14/2022 at 18:19 • point
Hi Michael. I don't saw your comment. Thanks for the warning.
I tried it for a quick moment only to check if controller was working after the buy.
I need to prepare the vacuum system with all correct conecction now. Already I have one roughing pump to make preliminary vacuum. I will follow the next steps:
I'm going to make rough vacuum with turbo->chamber valve opened but the valve for the roughingpump->turbo closed.
Later when 1*10-3 is reached I will close turbo->chamber valve, start pump for the turbo and then open the roughingpump->turbo valve.
Later I will start the turbo.
Later I'm going to close the roughingpump->chamber valve and then open the turbo->chamber valve.
https://hackaday.io/project/182104-vacuum/log/214291-vacuum-system-schema
I will make the system and steps described in the next youtube video:
https://youtu.be/-DsF6dDbGyo
Michael Fortner wrote 11/22/2022 at 02:01 • point
Be careful with your turbo!  Operating without a roughing pump and in open air can be destroy it.  There's nothing quite as gut wrench is hearing one spin up and suddenly go chug and die.
Project goal is to build a controller for home wastewater treatment plant.
Project Owner Contributor
DIY Wastewater Treatment Controller
leszek-wojcikleszek-wojcik
An Open Source Continuous Inkjet Printer
CIJ Printer
dominik-meffertDominik Meffert
The 2018 Hackaday Prize
Universal , scalable hydraulic muscle module.
Preloaded Hydraulic Muscle
consciousfleshconsciousflesh
A piezo inkjet printer built from scratch
DIY Inkjet Printer
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "vacuum", please tell us the reason.
Send message
Remove Member
