magnetron machining progress
06/17/2024 at 22:15 • 0 comments![]()
new magnetron design
06/13/2024 at 07:31 • 0 comments![]()
magnetron design progress
06/06/2024 at 09:01 • 0 comments -
new final setup
05/23/2024 at 11:13 • 0 comments![]()
more purchases
05/19/2024 at 21:47 • 0 commentsnew purchases:
8 copper non-resistive spark plugs
Loctite Hysol 1C / Torr Seal Vacuum Epoxy Resin Sealant
main chamber with 3x ISO160 outputs (+ 3x ISO160 centering rings)
1x ISO160 viewport
1x ISO160 blind plate
1x ISO160 to KF25
1x six way KF25
1x KF25 vent valve
5x KF25 blind plates
2x KF25 valves (I only had one)
2x KF25 bellows (300mm)
1x Pfeiffer PKR251 (KF40) + KF40 to KF25 reducer + KF40 clamp + KF40 centering ring with screen
1x 3 way KF25
1x KF10 blind plate (+ clamp, centering ring...) (for turbo vent output port)
more KF25 clamps (+ centering rings SS304)
more ISO clamps
vacuum system schema
12/14/2022 at 18:19 • 0 comments![]()
firsts connections for turbomolecular pump
12/14/2022 at 15:41 • 0 comments![]()
waiting for this firsts connections
11/18/2022 at 18:00 • 0 comments![]()
TPH-170 turbo pump + TCP-380 controller
11/17/2022 at 19:35 • 0 commentsStartup test for Pfeiffer TPH-170 turbo pump with TCP-380 controller
TCP 380 controller
05/11/2022 at 05:55 • 0 comments![]()
3drobert
