Ionarc
An oversized PCB with a flash based 7-segment decoder, debounced pulse generator and buttons for step, reset and BIN/DEC conversion.
0 followers
DO NOT ask why this is called Ionarc... I forgot after the years, and even if I remembered what it was, it would most likely be quite embarrassing. The long rows of headers are essentially unused - this module was part of a stack of PCBs, actually the base board of a small computer.
I am putting it here because I've used it quite a bit for debugging my CPU projects. The wires go to the RES, CLK and data bus lines and allow me single step and see what's on the bus in hex or decimal.
The jumper is there to choose between the single-step (CLK) push button, or you can use the multiplex signal for the 7-segment display as a clock.
ionarc.kicad_pcb
kicad_pcb - 615.61 kB - 10/14/2021 at 06:04
Download
Gerber.zip
Zip Archive - 198.75 kB - 10/14/2021 at 06:04
Download
ionarc.sch
sch - 34.25 kB - 10/14/2021 at 06:04
Download
ionarc.pro
pro - 3.52 kB - 10/14/2021 at 06:04
Download
7segdrv.c
C Source File - 7.80 kB - 10/14/2021 at 06:04
Download
View all 6 files
