Basic source code
10/14/2021 at 20:36 • 0 commentsThe program is quite simple. This version only displays the current configuration. Many AT commands are available (look at the datasheet) and are commented out, enable them at your convenience.
/* * HC12config.ino * created 20211014 by Yann Guidon * * Configure a HC12 module for custom operation. * Not interactive : define the parameters in the #defines. * * Connections: * * Arduino: HC12: * D4 RXD * D5 TXD * D6 SET */ #include "Arduino.h" #include "SoftwareSerial.h" #define INIT_BPS (9600) #define HC12RX (4) #define HC12TX (5) #define HC12SET (6) #define LED_RED (13) SoftwareSerial HC12(HC12TX, HC12RX); // actual order from the Arduino point of view : RX, TX void HC12_flush() { while (HC12.available()) { Serial.print("Flushing "); Serial.println(HC12.read()); } } // Put the HC12 is config mode: void HC12_SET() { pinMode(HC12SET, OUTPUT); digitalWrite(HC12SET, 0); } // Exit from config mode: void HC12_UNSET() { pinMode(HC12SET, INPUT_PULLUP); } // Send a given command and display the result void ATcmd(const char* cmd) { for (uint8_t i=0; cmd[i]; i++) { HC12.write(cmd[i]); Serial.write(cmd[i]); } HC12.write(13); // replace the trailing null byte // by the <CR> character. Serial.print('\n'); delay(200); // Might need increase if speed is very low while (HC12.available()) { Serial.write(HC12.read()); } } void setup() { pinMode(LED_RED, OUTPUT); digitalWrite(LED_RED, 1); Serial.begin(9600); Serial.println("Probing HC12..."); HC12_UNSET(); HC12.begin(INIT_BPS); delay(100); HC12_SET(); delay(100); HC12_flush(); // First check : send the AT command // and expect AT<CR><LF> HC12.write('A'); HC12.write('T'); HC12.write(13); // optional ? delay(200); uint8_t a=HC12.available(); if ((a != 4) || (HC12.read() != 'O') || (HC12.read() != 'K') || (HC12.read() != 13) || (HC12.read() != 10)) { Serial.print(a); Serial.println(" char received.\nHC12 KO ?\n"); HC12_flush(); return; } // ATcmd("AT+DEFAULT"); // Restore default settings ATcmd("AT+V"); // display firmware version // ATcmd("AT+C042"); // change to channel 42 // ATcmd("AT+B1200"); // change serial speed // ATcmd("AT+FU4"); // sets the interface to 1200bps, and OTA to 500bps ATcmd("AT+RX"); // Display all the configuration parameters HC12_UNSET(); Serial.println("\nHC12 ok\n"); } void loop() { // nothing to be done here. digitalWrite(LED_RED, 0); }
Operation is pretty simple :
- Wire the boards as shown in the code.
- Open the source code in the Aruino IDE
- Plug the board on the USB port.
- Open the serial monitor to display all the messages from the Arduino board.
- Compile & upload the code
- Examine the messages on the monitor : If "HC12 KO ?" appears, check your connections and the settings, in particular INIT_BPS. For example when INIT_BPS=9600 and the HC12 is at 1200bps, the flush will display a number of 128 and 0.
- The ATcmd() calls are executed: So far only configuration parameters are read. You can uncomment the desired commands to suit your needs.
- Goto 5 until you reach the configuration you desire.
