The 3D File shelling for thickness
10/20/2021 at 20:42 • 0 commentsI start in Netfabb- scale the mask to size, and slice the file without closing the objects. I export the file to Meshmixer and select an area, then modify and "create facegroup"; duplicate and inverse the selections and delete excess file parts.
Don't forget the eye sockets! but you can also use the meshmixer boolean option too...
Then select the group, Modify > Offset, if you're lucky then you can use the 'connected' button... if not then you can use the 'bridge' tool to connect the two shells together (then use Netfabb to close the holes {which I find to be easier than using Meshmixer)
M3 x .5 Screw
10/20/2021 at 20:04 • 0 commentsThe Turn Table Motor Screw is an M3 x .5
