A_Frame_07.stl
Standard Tesselated Geometry - 469.61 kB - 10/16/2021 at 19:21
Download
Base_09.stl
Standard Tesselated Geometry - 576.25 kB - 10/16/2021 at 19:21
Download
Conn_Rod_02.stl
Standard Tesselated Geometry - 74.01 kB - 10/16/2021 at 19:21
Download
Controller_Bracket_11.stl
Standard Tesselated Geometry - 211.61 kB - 10/16/2021 at 19:21
Download
Controller_Cover_02.stl
Standard Tesselated Geometry - 139.73 kB - 10/16/2021 at 19:21
Download
Crank_Disk_02.stl
Standard Tesselated Geometry - 50.38 kB - 10/16/2021 at 19:21
Download
Cylinder_04.stl
Standard Tesselated Geometry - 158.87 kB - 10/16/2021 at 19:21
Download
Driven_Gear_02.stl
Standard Tesselated Geometry - 427.04 kB - 10/16/2021 at 19:21
Download
Gearbox_Frame15mm_01.stl
Standard Tesselated Geometry - 316.29 kB - 10/16/2021 at 19:21
Download
Gearbox_Frame16mm_05.stl
Standard Tesselated Geometry - 437.39 kB - 10/16/2021 at 19:21
Download
Insert_Rectangle_02.stl
Standard Tesselated Geometry - 32.50 kB - 10/16/2021 at 19:21
Download
Insert_Rectangle_03.stl
Download
Insert_Round_01.stl
Standard Tesselated Geometry - 45.98 kB - 10/16/2021 at 19:21
Download
Insert_Triangle_01.stl
Standard Tesselated Geometry - 32.31 kB - 10/16/2021 at 19:21
Download
Lower_Stiffener_02.stl
Standard Tesselated Geometry - 27.43 kB - 10/16/2021 at 19:21
Download
Motor_Mount_Lower_04.stl
Standard Tesselated Geometry - 193.15 kB - 10/16/2021 at 19:20
Download
Motor_Mount_Upper_02.stl
Standard Tesselated Geometry - 94.52 kB - 10/16/2021 at 19:20
Download
Pinion_Gear_07.stl
Standard Tesselated Geometry - 241.00 kB - 10/16/2021 at 19:20
Download
Piston_05.stl
Standard Tesselated Geometry - 288.95 kB - 10/16/2021 at 19:20
Download
Piston_Keeper_02.stl
Standard Tesselated Geometry - 53.40 kB - 10/16/2021 at 19:20
Download
Stiffener_01.stl
Standard Tesselated Geometry - 27.23 kB - 10/16/2021 at 19:20
Download
Top_Plate_09.stl
Standard Tesselated Geometry - 176.06 kB - 10/16/2021 at 19:20
Download
Upper_Stiffener_02.stl
Standard Tesselated Geometry - 32.50 kB - 10/16/2021 at 19:20
Download
