Seeed Studio Fusion PCB Assembly Service takes care of the entire fabrication process from PCB manufacturing parts sourcing, assembly, and testing services, so you can be sure that they are getting a quality product. After gauging market interest and verifying a working prototype, Seeed Propagate Service can help you bring the product to market with professional guidance and a strong network of connections.
Features
• Linear Charge Management Controller:
- Integrated Pass Transistor
- Integrated Current Sense
- Reverse Discharge Protection
• High-Accuracy Preset Voltage Regulation: + 0.75>#/p###
• Four Voltage Regulation Options: - 4.20V, 4.35V, 4.40V, 4.50V
• Programmable Charge Current: 15 mA to 500 mA
• Selectable Preconditioning: - 10%, 20%, 40%, or Disable
• Selectable End-of-Charge Control: - 5%, 7.5%, 10%, or 20>#/p###
• Charge Status Output - Tri-State Output - MCP73831 - Open-Drain Output - MCP73832
• Automatic Power-Down
• Thermal Regulation
• Temperature Range: -40°C to +85°C
• Packaging: - 8-Lead, 2 mm x 3 mm DFN - 5-Lead, SOT-23
Bill of Materials
Schematics
3D View
For the Gerber File, Follow and message us on
YouTube: https://www.youtube.com/channel/UC8mQvRi15t0JOyzw6GYtnMA
LinkedIn: https://www.linkedin.com/in/technical-avant-garde-2761261b0/
mbsg99
Lithium ION
hesam.moshiri
icstation
Anuradha Gunawardhana
