I'm pretty familiar with the AWS products, I know that the tyhac device will need to upload audio samples to the cloud. To do this I would like to store them in an S3 bucket, to use an s3 bucket I want to make sure it is protected.
I need a way to ensure the right users or devices are uploading the bucket. The API GW can be used with an API-KEY and a Lambda function to generate an S3 pre-signed URL, this URL could then be used by the device to upload the file. Sounds easy enough:
AWS IoT
I want the device to be securely enrolled as an IoT device. The device itself should use certificate based authentication, AWS IoT provides this service and more. Can we just use AWS IoT instead of API-GW to handle the pre-signed url? Yes, there are many actions you can perform using rules and because I want to instead data into a database as well this will provide a single service entry point that is more secure and easier to maintain:
