This is v2, which is smaller, but doesn't require cutting the LED strip into 4 segments. The strip wraps around the model seamlessly. Corners are really close together. The other model is nicer, but trickier to put together.
Standard Tesselated Geometry -
609.85 kB -
02/14/2023 at 12:46
