1Setup
Firstly connect up the Servo Motor, Ultrasonic sensor with the AmebaD board.
2Programming
#include <AmebaServo.h> AmebaServo myservo; const int trigger_pin = 12; const int echo_pin = 13; const int inter_time = 100; int time = 0; void setup() { Serial.begin(115200); myservo.attach(8,500,2400); pinMode(trigger_pin, OUTPUT); pinMode(echo_pin,INPUT); delay(3000); } void loop() { float duration,distance; digitalWrite(trigger_pin,HIGH); delayMicroseconds(1000); digitalWrite(trigger_pin, LOW); duration = pulseIn(echo_pin,HIGH); distance = (duration/58); Serial.print(distance); Serial.println(" cm"); time = time + inter_time; delay(inter_time); if(distance < 10) { for(int i = 1500; i>= 1100; i-=25) { myservo.writeMicroseconds(i); Serial.println("2"); delay(1000); } delay(1000); for(int i=1100; i<=1500; i+=25) { myservo.writeMicroseconds(i); Serial.println("1"); delay(1000); } } }The source code could found in my github: https://github.com/daphwl/Touchless-Automatic-Mini-Dustbin
3Final Results
When you place your hand near the ultrasonic sensor, the dustbin will open and when your hand is away from it, the dustbin would close.
