A project log for EUfON FLT
MIDI Wind controller based on ESP32 via BLE.
As follows,dock Printed.
Structure designed to control the incoming air.
It would be only a temporary solution.A screenshot's updated to a new log.
Hi !
Do you have some other views of your pressure adjustment device ? I too would like to add screw tune, but your design seem.... Complex (like why so many channels ?).
I just explain it.
The screw left is just for fixing.
The screw buttom right is for adjusting the blowing rate outside.Fastening it would make pressure higher.
The screw mid-right is nothing for right now.
The tune top connected to the pressure meter module.It's low-cast.
I'll update all BOM maybe in next version.
(Sorry for my LAZY head)
Yes, delete it Cancel
Hi !
I just explain it.
