W25Q80DV Simulator - Exercise 3b
A project log for Jungle Vine Swing Robot
Controlling reeling in/out a rope
ekEK 12/10/2021 at 03:565 Comments
Breaking problems down into smaller bits really helps to make a solution. The process doesn’t have to be linear like what you see below. Often working on one sub-problem helps to give a better conceptual understanding of the whole, so jumping back and forth between sub-problems is natural (despite it not seeming that way).
Exercise 3b: Make a flash simulator
To figure out where to start, list out the super basic elements. There’s gonna be an array, and the minimum functionality is to read, write, and erase.
Here’s the steps of breaking the problem down into sub-problems, and the sub-problems into further smaller sub-sub-problems. Below this list are my notes. Coding was only done at the very end. The majority of time was figuring out the problem, reading the documentation, and of course - learning!
Breakdown
Step 0: Getting background information
Step 1: Determining the buffer
Step 2: Determine the address
Step 3: Code the buffer
Step 4: Make erase function
Step 5: Make read function
Step 6: Make write function
Step 7: Make test flow
Step 8: Make tests to fail
Step 9: Code it
Notebook
Step 0
Step 1
Step 2 (Do not follow!!)
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Step 9
Code
Here’s the code on Github
Time
10.75 hours figuring out & learning
3 hours coding
1 hour documenting
ty wrote 12/13/2021 at 23:10 point
+1 for the 0-indexed steps
EK wrote 12/13/2021 at 23:59 point
secrethai000 wrote 12/12/2021 at 17:58 point
I am anew user how can i learn hacking
Paul Stoffregen wrote 12/11/2021 at 11:08 point
C7h/60h means you can send either byte.  If you've previous done the write enable command, and none of the sectors are write locked in the status register, sending either byte 0xC7 or 0x60 will cause the entire chip to erase.
EK wrote 12/11/2021 at 21:32 point
Hi Paul! Cool! That's good to know about the status register as well. (Oops)
