Reflash to version Badge Berlin 2023.zip
Please download, unzip and read the attached .TXT file
x-zip-compressed -
10.75 kB -
04/28/2023 at 19:31
Download
- The new version of firmware, created in February 2023. - The year and v1r1 extension are generic, that`s why it's 2022 v1r1. - Contains new functions described in Manual Rev4a.pdf, and some minor bug fixes - This version of firmware was prepared for the Berlin conference, but due to a manufacturing error in China, the old version was programmed. - To open the project, install MPLAB X IDE - To program using MPLAB X IPE, use this file: \dist\default\production\Badge2022_v1r1.production.hex (the year and v1r1 extension are generic)
x-zip-compressed -
322.08 kB -
04/27/2023 at 18:14
Download
1 Manual Rev4a.pdf
User Interface, Commands and Modes of Operation
Adobe Portable Document Format -
1013.21 kB -
11/11/2022 at 20:45
Preview
2 Instruction Set Rev4.pdf
Detailed explanation of all instructions
1.05 MB -
11/03/2022 at 02:25
Preview
3 SFR Rev4a.pdf
Special Function Registers. NOTE: Revision 4a (Nov.03.2022) contains an error fix (page 24, KeyReg). Please use this revision if you have Rev4 or lower.
647.36 kB -
11/04/2022 at 03:07
Preview
4 DIR Mode Rev4.pdf
Instructions supported in Direct Mode (a simple mode, which does not support programming, Data Memory usage, Indirect Addressing and instructions with N or M operands)
642.69 kB -
11/03/2022 at 02:24
Preview
5 Hardware Rev4b.pdf
Schematic diagrams and characteristics
614.59 kB -
11/04/2022 at 05:55
Preview
Badge Final Modified PCB Outputs.zip
- File with the extension CSPcbDoc is the PCB file - PCB dimensions: 175×94 mm - PCB file was modified, so that it requires one-color silkscreen only (yellow lines were turned to white, but with 4 mil thickness)
x-zip-compressed -
10.84 MB -
10/18/2022 at 18:19
Download
Badge2022_BOM_V2.xlsx
Bill Of Material. (note: PCB and batteries not included)
sheet -
15.37 kB -
10/20/2022 at 01:50
Download
Placement.zip
Component placement (Top + Bottom JPG)
x-zip-compressed -
2.34 MB -
10/21/2022 at 19:18
Download
