After completing all the actual hard work, digging two sediment catch pits, fixing a trencher, trenching, and actually laying the pipe needed to generate the needed head pressure, we had to move on before I could actually assemble the prototype.. days after I finished it.
At least Don has a working drainage system now, so I guess that works.
I do have a lot of media for this. Some of it may get posted.
This was actually a good idea. 80% efficiency of a 93% efficient system and you can laser cut it is nothing to sneeze at. Someday.
MasterOfNull
