This is the result of a weekend project at a family friends house.
It is a laser cut water wheel created by taking a cross section of a Pelton turbine and positioning that curve such that the water streams follow it for the duration of the 1/60 rotation of the wheel required.
A nice video showing a classical Pelton turbine:
Pelton turbines can achieve upwards of 93% efficiency in converting the energy of a stream of water to rotational energy. This project will not achieve that.
Due to the various losses I have had to introduce (water escaping off of the vanes and less than 90 degree incident angle required for the jets/vanes), I am expecting this project to land somewhere around 80% efficiency. Converting this to firing at the vanes from the inside might mitigate 10% of those losses. Might.
My target output power for this project is 50-1200W.
Lots of media, no time to put it up yet.
Soon.
