After my previous build of a chorded keyboard using Cherry MX Switches, it was clear that I needed to work with smaller components if I was going to have any more keys. Not wanting to solder to the pins of smaller switches and deal with designing complex mounting to make them secure, I decided to design a pcb segment for 4 switches.
I am planning on using an Arduino Connect as the main micro to run the chorded keyboard, and it has enough GPIO for me to be satisfied wiring the switches independently, with a shared ground plane.
You can find the first revision of the segments on Oshpark already!
Enjoy,
Atltvhead
