Here is an attempt in taking the strip concept and making it a bit smaller and easier to assmble.
I moved all components to the top to allow automated assembly. If we use an assembly service anyways, we can switch all the passives to 0402 and save a lot of space. The VCC power rail is now routed on the rear side, while there is a large groundplane for GND on both sides of the PCB, that will also help with shielding.
This new arrangment allows reducing the strip width to 0.2". Each element is a single inverter with pull up at the input. Multiple inverters can be combined to form wide input NOR2 gates in RTL.
A base resistor bypass cap is added to improve switching speed. There is no space for a schottky clamp diode, but probably the parasitics of the wiring scheme on a breadboard will limit the achievable speed a bit anyways. Each element also has a decoupling capacitor.
Open and still unsolved: How to connect to the power lines?
Some more renders below.
Edit: One could also fit a clamping diode in there. But then the text has to be moved to the rear side. Second from left:
@Tim The "edit" seems to be only on one gate.
What package footprint did you use ?
indeed. Just a test.
SOD-323
nice :-)
"How to connect to the power lines?" I contemplated this question already.
I imagined something like the "real" LED strips, which can be joined by soldering exposed pads. In our case, the pads can simply be exposed copper. A bit of resistor leg might also help.
But the corollary is : how do you break/cut the strip to a desired length ? V-groves ? microdrills ?
The design is probably too small for V-groves. But I made very small breakout boards before by separating them with microdrills on 0.8mm FR-4 thickness. You could simply cut them apart with scissors.
I have an open order at JLCPCB and just added a few PCBs as above for testing without assembly. I can share some with you.
Awesome !
More strips per board could be achieved if you let go of the I and O marks, or even put them on the other side of the board :-)
yeah, i though about that. Could flip the parts to the bottom. But then it is always better to be able to look at the components
flip the marking to the bottom instead, it's the same, right ?
"probably the parasitics of the wiring scheme on a breadboard will limit the achievable speed"
Why limit ourselves to breadboards ? ^_^
