0.2" wide strips for autmomated assembly
A project log for Logic strips
Attempting to lower the cost and augment flexibility of discrete logic designs.
timTim • 12/11/2021 at 22:20•12 Comments
Here is an attempt in taking the strip concept and making it a bit smaller and easier to assmble.
https://cdn.hackaday.io/images/3771621639256229871.file-1639256229856-305038108
I moved all components to the top to allow automated assembly. If we use an assembly service anyways, we can switch all the passives to 0402 and save a lot of space. The VCC power rail is now routed on the rear side, while there is a large groundplane for GND on both sides of the PCB, that will also help with shielding.
This new arrangment allows reducing the strip width to 0.2". Each element is a single inverter with pull up at the input. Multiple inverters can be combined to form wide input NOR2 gates in RTL.
A base resistor bypass cap is added to improve switching speed. There is no space for a schottky clamp diode, but probably the parasitics of the wiring scheme on a breadboard will limit the achievable speed a bit anyways. Each element also has a decoupling capacitor.
Open and still unsolved: How to connect to the power lines?
Some more renders below.
https://cdn.hackaday.io/images/2897591639256257014.file-1639256256992-378518079
https://cdn.hackaday.io/images/8716031639256285593.file-1639256285577-194500910
Edit: One could also fit a clamping diode in there. But then the text has to be moved to the rear side. Second from left:
EDIT2: A version with drill-lines for easy separation
monsonite wrote 09/14/2025 at 23:44 • point
Yann - the transistor inverter is essentially a 4-pin device: Input, Output, VCC and GND.
Add another couple of pins for VCC and GND, and arrange in a DIL format.  Pin headers are cheap and convenient.
Ideas are great, but it's the pesky, practicalities of packaging that takes up the most thinking time.
Yann Guidon / YGDES wrote 12/13/2021 at 01:25 • point
@Tim  The "edit" seems to be only on one gate.
What package footprint did you use ?
Tim wrote 12/13/2021 at 06:33 • point
indeed. Just a test.
SOD-323
Yann Guidon / YGDES wrote 12/13/2021 at 06:35 • point
nice :-)
Yann Guidon / YGDES wrote 12/11/2021 at 23:23 • point
"How to connect to the power lines?" I contemplated this question already.
I imagined something like the "real" LED strips, which can be joined by soldering exposed pads. In our case, the pads can simply be exposed copper. A bit of resistor leg might also help.
But the corollary is : how do you break/cut the strip to a desired length ? V-groves ? microdrills ?
Tim wrote 12/16/2021 at 06:33 • point
The design is probably too small for V-groves. But I made very small breakout boards before by separating them with microdrills on 0.8mm FR-4 thickness. You could simply cut them apart with scissors.
Tim wrote 12/20/2021 at 16:08 • point
I have an open order at JLCPCB and just added a few PCBs as above for testing without assembly. I can share some with you.
Yann Guidon / YGDES wrote 12/20/2021 at 16:19 • point
Awesome !
Yann Guidon / YGDES wrote 12/11/2021 at 22:48 • point
More strips per board could be achieved if you let go of the I and O marks, or even put them on the other side of the board :-)
Tim wrote 12/11/2021 at 22:56 • point
yeah, i though about that. Could flip the parts to the bottom. But then it is always better to be able to look at the components
Yann Guidon / YGDES wrote 12/11/2021 at 23:08 • point
flip the marking to the bottom instead, it's the same, right ?
Yann Guidon / YGDES wrote 12/11/2021 at 22:47 • point
"probably the parasitics of the wiring scheme on a breadboard will limit the achievable speed"
Why limit ourselves to breadboards ? ^_^
