Lightest GPS quad?
Modified nano long range to be super light
Public Chat
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
It's a 31.5g without battery 45-50g auw gps equipped quad that flies 10+ minutes on under 1000mah 1s batteries. I'll be building a updated version when I finish some other projects that will use an ExpressLRS integrated flight controller and hope to get it at or even under 30g dry weight. Frame is modified Dave C nano long range that uses 2mm carbon rod for arms.
https://www.thingiverse.com/thing:4875765
https://www.youtube.com/watch?v=V-Xw54VlyDw&t=170s
https://www.youtube.com/watch?v=WIGW5-ZeEd0
First video is a short "long range" second is an endurance test.
