An inverter that uses the minimum number of components for converting a 12 V DC to 220 V AC is called a simple inverter.
Inverter Circuit Gerber .rarGerber FileRAR Archive - 203.91 kB - 11/24/2021 at 10:51 |
Story
An inverter that uses the minimum number of components for converting a 12 V DC to 220 V AC is called a simple inverter. A 12 V lead-acid battery is the most standard form of battery that is used for operating such inverters.
Disclaimer: Be extra careful with this project as it produces a High Voltage - High Current output.
Step 1: Get your PCB ready!
Talking About Electronics
Related Download Files
Step 2: Get all the Components Listed below images.
Step 3: Place all the components on PCB and solder it properly.
Step 4: After soldering all the components to PCB, connect one input wire of the transformer to switch and the other wire to the left side of the female socket as shown below.
Step 5:
Step 6:
Final step: Connect the 12V Lead Acid Battery to the inverter, & your Inverter is now Ready to power up your Small Ac appliances.
New users will also get a $30 coupon while registering at JLCPCB via this blue link.
Thank you for reading this guide, hopefully, this guide provides full steps to help you to create your own Diy Simple Inverter. If you have any questions please post them in the comment section below.
Im truly just starting into this field. Can you give a lil more details on component list. Like part numbers or sizes. Example pcv board, or a/c switch. I now need to figure out how to order that pcb board. I looked sweet. I downloaded from the link but it has many files attached. I need to reread all this a figure out how to. I'll get it. Just a lil slow first time
