Hackaday.io Hackaday.io
Sign up Log in
PicoBerry (tiny CM4 carrier board)
Tiny Raspberry Pi CM4 carrier board with full 40-pin GPIO header
mirkoMirko
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
3.6k views
6 comments
23 followers
  • Description
  • Details
  • Files 2
    • View all
  • Components 0
  • Logs 4
    • View all
  • Instructions 0
  • Discussion 6
View Gallery
Public Chat
3.6k
6
23
18
Team (1)
  • mirkoMirko
Join this project's team
  • PicoBerry
completed project
hardware
raspberry pi CM4 Carrier Board
This project was created on 11/24/2021 and last updated 3 years ago.
Description
Meet PicoBerry!
Tiny carrier board with a full 40-pin GPIO port for the Raspberry Pi CM4 module.
Short specification:
- USB-C for power supply (5VDC/3A),
- full 40-pin GPIO header for connecting HAT boards,
- 2x user LEDs (green/red),
- support only CM4 versions (with eMMC onboard, CM4 Lite are not supported),
- standard ACT/PWR LEDs,
- 2-layer PCB, 20x70mm.
Project published as Open Source Hardware (OSHW) under CERN OHL v1.2 (Open Hardware Licence).
You can connect to the CM4 module standard HAT boards, such as LCD screens (with SPI or DPI interfaces), audio DAC boards, RS232/485 or CAN interfaces, and many more...
Files
PicoBerry_v1.0_project_(CERN_OHL_v1.2_license).zip
x-zip-compressed - 4.22 MB - 10/24/2022 at 01:26
Download
PicoBerry_V1.0_Schematic_2022-01-22.pdf
PicoBerry - full schematic file
Adobe Portable Document Format - 573.50 kB - 01/12/2022 at 09:05
Preview
Project Logs
Collapse
  • Now published as Open Hardware (OSHW)
    Mirko • 10/24/2022 at 01:25 • 0 comments
    Source files:
    https://github.com/mfolejewski/PicoBerry
  • Schematic file
    Mirko • 01/12/2022 at 09:06 • 0 comments
    Here you can find full PDF schematic:
    https://cdn.hackaday.io/files/1827477818647648/PicoBerry_V1.0_Schematic_2022-01-22.pdf
  • Soldering and bring-up process...
    Mirko • 11/24/2021 at 20:34 • 0 comments
    It's time to solder a few boards (missing components - colored pin header + USB-C connector)...
    ImageDone! Let's test these boards...
    OK, #PicoBerry board is working!
    Smallest CM4 carrier board with full 40-pin GPIO header port.
    Sorry about the ugly video quality.
    https://twitter.com/Mirek34416541/status/1463599187786874887
  • PCB boards just arrived
    Mirko • 11/24/2021 at 20:31 • 0 comments
    PicoBerry REV1 boards just arrived!
    This time I reduced the PCB pad size for the Hirose connectors to improve soldering and component placement.
    ...against component floating during reflow soldering.
    It should be better now.
View all 4 project logs
Log In/Sign up to comment
Sign up with Github
OR
David Michaeli wrote 11/25/2021 at 18:44 • point
Oh yes of course. SMI is just a secondary memory interface exposed on the RPI in ALT5 GPIO2-27
If you expose those default RPI GPIO2 to GPIO27 then you implicitly expose also the SMI. And that interface is great because it is a high-speed bus for bulk transfers.
see my project:
https://github.com/cariboulabs/cariboulite
did not write a full documentation on that yet but, its there...
So you got an amazing idea here with PicoBerry that exposes ComputeModule as if it was a RPI4 and I'm surprised Raspbery Pi didn't do it yet :)
Anyway, by taking into account the signal integrity in your board (proper grounding) you can proof it for these high speed applications.
Mirko wrote 11/25/2021 at 21:27 • point
I have not heard about this interface so far. Thanks!
I don't have the resources now to test SMI mode. Anyway sounds interested (high-speed interface).
Maybe PicoBerry requires to length match GPIO traces and correct impedance tracks (50Ohm?) and add extra 2 reference ground planes. This can be a future plan (I'm too busy up to the end of this year).
Thanks for your info!
David Michaeli wrote 11/25/2021 at 11:20 • point
Regarding the board - did you consider high speed interfaces like the SMI? in terms of impedance control, etc.?
Mirko wrote 11/25/2021 at 12:53 • point
SMI interface? Hmm... All the high-speed interfaces are connected to the second Hirose connector.
This is a simple carrier board with only exposed GPIO lines.
Can you explain about SMI?
David Michaeli wrote 11/25/2021 at 11:19 • point
This project is just amazing. I want to have one of those boards for CaribouLite over the RPI-CM... any way to get it?
Edit: Ok now I see its a two layer board. I would consider turning it into a 4 layer stack with two gnd planes in the middle. If you need help with it, just tell me. you can also route the power partial planes there so it will be much simpler. Then you get a really good power / signal integrity for those high speed lines
I use SMI, some other will use DPI (display parallel lines) to connect an external LCD. Both of which require a good grounding.
Anyway, if you need help, I'm here. David
Mirko wrote 11/25/2021 at 12:56 • point
The project can be modified to add extra reference planes for signal lines (GPIOs) and for power rails.
If you are interested to order 1pcs in the current version just let me know (DM).
There is no high-speed signals, they are located on the second Hirose connector.
IoT Rapid prototyping platform : Atmega328P at heart | ESP-01 + Xbee radio | Sensors - DS18B20 + LDR | Enough GPIOs
Project Owner Contributor
Arduino Enabled : (ESP8266) WiFi & Xbee IoT Board
amar-potdarAmar Potdar
RP2040 board with business card form factor and compatible with Arduino Uno
Carduino Pi
mirkoMirko
Arduino from Poland (RP2040 board)
Polanduino
mirkoMirko
Made a breakout board for Lattepanda Delta for using its onboard Atmega32U Microcontroller.
LattePanda Delta Breakout Board
arnov-sharmaArnov Sharma
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "PicoBerry (tiny CM4 carrier board)", please tell us the reason.
Send message
Remove Member
