Support Flyver
04/03/2015 at 12:01 • 0 comments -
Serving a webpage on the drone
04/01/2015 at 07:04 • 0 commentsFlyver SDK allows you to serve a webpage directly from your smartphone.
To do so, you must put all your webpage files(.html, .css, .js, images) in the FlyverCore/src/main/assets/webpage/ folder(only plain files, folder structure is not supported for now) and the page will be served on the device's IP address. The files in this folder are deployed automatically with the .apk of the application
The HTTP server used for this is NanoHTTPD, which is subclassed in utils/java/co.flyver.utils/NanoHTTPDServer, which implements its serve method
Any questions? Ask in the comments below.
This article was originally posted on the Flyver Github
Flyver IOIO Shield
03/20/2015 at 15:57 • 0 commentsFlyver now has its own IOIO OTG shield for the Flyver Dev Kit. The shield will make easier to connect without messy cables.
Air Quality Monitor App
03/19/2015 at 11:54 • 0 commentsThis drone app let's you measure various air quality metrics and pollution and build a heatmap of the data.
The data is stored locally on the drone as .csv file and served as a webpage with Google maps APIs. -
Flyver Video Promo
03/19/2015 at 10:10 • 0 comments -
Hackadrone Event
03/02/2015 at 13:46 • 0 commentsWe are organising hackadrone events. Here is a short video of the last one.
November Newsletter
11/11/2014 at 13:25 • 0 commentsOur newsletter for November
http://us8.campaign-archive1.com/?u=ce05242e0ed80b547eb194ea0&id=3e4b98f167&e=b7e308dd0c
Tihomir Nedev
