11The complete 555 circuit
Finally interconnecting the tested building blocks of 555.
Tested and modified by - Rudraksha Vegad Breadboard testing:
12Interconnection planning and soldering
To Correctly connect all the building blocks - Voltage comparators, SR flip - flop, Buffer, Reset transistor, Discharge transistor and Voltage divider, I designed a Hand drawn Layout to accurately route the wiring, jumpers, Soldering junctions, output pin pattern on A4 sheet and then transferred it to physical wooden board.
13Building the 555 box
