Committed to providing one-stop electronic hardware services for over a decade, Seeed Fusion has the expertise and engineering insight to deliver streamlined PCB assembly at low costs and is equipped with a wide range of value-added services and capabilities. Check out their website to know about their manufacturing capabilities and service.
To available Seeed Studio Sevices: https://www.seeedstudio.com/pcb-assembly.html
Introduction
The TMP117 is a high-precision, digital temperature sensor. What makes the TMP117 stand out is its ability to be accurate down to ±0.1°C (from -20°C to 50°C). The measurements can also have a resolution of 0.0078°C! This is great for projects that require more stable temperature readings. There are also additional features that come with the TMP117. Some of these features include offsetting the temperature, entering the low-power mode, and averaging the readings.
- Uses I2C interface (Qwiic-enabled)
- Four selectable addresses
- 0x48 (default), 0x49, 0x4A, 0x4B
- 16-bit resolution, 0.0078°C
- High accuracy, digital temperature sensor
- ±0.1°C (max) from –20°C to 50°C
- ±0.15°C (max) from –40°C to 70°C
- ±0.2°C (max) from –40°C to 100°C
- ±0.25°C (max) from –55°C to 125°C
- ±0.3°C (max) from –55°C to 150°C
- Operating temperature range
- -55°C to +150°C
- Operating voltage range
- 1.8V to 5.5V
- Typically 3.3V if using the Qwiic cable
- Low power consumption
- 3.5µA (1-Hz conversion cycle)
- 150nA (shutdown current)
- Programmable operating modes
- Continuous, one-shot, and shutdown
- Programmable temperature alert limits
- Selectable averaging for reduced noise
- Digital offset for system correction
- NIST traceability
Components Required
Schematics
3D view
For the Gerber File, Follow and message us on
YouTube: https://www.youtube.com/channel/UC8mQvRi15t0JOyzw6GYtnMA
LinkedIn: https://www.linkedin.com/in/technical-avant-garde-2761261b0/
mbsg99
Lithium ION
Arnov Sharma
