1Hardware Connections
The ESP32 board is placed on a breadboard. The WS2812B individually addressable LED strip is powered via an External Power Supply and given signal input from pin 17 of the ESP board. The external BLE device is powered with its visibility setting on, in order to make it discoverable for our ESP board. Here, we used a Mi band as the external BLE device.
2Setting up Application on Toit
First, set up your Toit account and ESP32 device following Toit’s Quick Start Guide.
From the Toit CLI, you need to install the pixel_strip library for the WS2812B LED strip provided in the Toit package registry. For that, in Toit CLI, open your application directory and run the command
$ toit pkg install pixel_strip
Next up, we’ve used Visual Studio Code to implement and deploy the application.
The program first imports all the necessary libraries including the BLE library.
//Import libraries import ble import bitmap show bytemap_zap import pixel_strip show UartPixelStrip
We declare some necessary global variables and initialize signal pin 17 for our WS2812B LED strip. These values are customizable as per the user's need and available inventory.
PIXELS ::= 30 // Number of pixels on the strip. UL::= -40 // Upper limit of rssi. LL::= -100 // Lower limit of rssi. BLE_DEVICE ::= "d3:3e:e3:cd:6b:10" // Device to watch. main: pixels := UartPixelStrip PIXELS --pin=17 // Output pin for UART 2. r := ByteArray PIXELS g := ByteArray PIXELS b := ByteArray PIXELS
Here, PIXELS corresponds to the total number of available LEDs on the WS2812B strip.
Next, we scan for external available BLE devices from the ESP32 board. Uncomment the print statement to see the scan results. Note the address of your external BLE device in use.
device := ble.Device.default device.scan: | remote_device/ble.RemoteDevice | // Start scanning for devices. //print "$remote_device $remote_device.data.name" address := "$remote_device.address" if address == BLE_DEVICE: rssi := remote_device.rssi print "$rssi dBm"
Make sure you enter the correct BLE address in the code. The variable rssi stores the signal strength of only that particular address BLE device you entered before.
Next, we initialize an array for the WS2812B LED strip taking into consideration the total number of available LEDs to suit any length strip. The first for loop assigns colours to all available pixels and makes a colour pattern from red to green.
step:= 255 / PIXELS // Step size for colour pattern, 8 in this case. r[0] = 0xff // Colormax hexcode. g[0] = 0x00 // Colormin hexcode. b.fill 0x00 for i := 1; i < PIXELS; i++: // Initialize led strip’s colour pattern. r[i] = r[i-1] - step g[i] = g[i-1] + step
The variable PIX stores the number of pixels that should glow for the corresponding rssi value. The second for loop turns all other led pixels off.
// Linear conversion to find number of LEDs to glow as per rssi value // range 0 to (PIXELS-1) PIX := ((((rssi - LL) * (0 - (PIXELS - 1))) / (LL - UL)) + 0).to_int // print PIX for j := PIX; j < PIXELS; j++: r[j] = 0x00 g[j] = 0x00
Finally, the optimised array is given as an output to the led strip via the signal pin.
pixels.output r g b sleep --ms=1
3Deploying the Application
Toit’s VS Code extension is used here to deploy the application to the ESP board. Open the application’s .toit/.yaml files, click on deploy/run buttons, select your device and the application gets deployed to the board.
See the output on the VS Code’s Toit output (device_name) and Toit logs (device_name) panel.
As the Mi band comes close to the ESP board due to strong signal strength, higher RSSI values are obtained. When the device goes far from the board, lower RSSI values are obtained. These RSSI values are correspondingly mapped on the WS2812B LED strip from RED to GREEN along its length.
Application Video:
