Sometimes placing small SMD components can be frustrating, especially when they get stuck at the tip of the tweezers. SMD pen is a good alternative that is also fun to use, but most market solutions are based on overshoot aquarium pumps requiring AC. ISAC works off-the-grid, makes very low noise and it's powerful enough for most works.
Files
base_2.stl
bottom half casing
Standard Tesselated Geometry -
1.19 MB -
12/14/2021 at 15:48
Download the STLs to print. I made some casing in PLA (0.2 layers, no supports) and in red resin (0.065 layers, 10x base layers @ 30 sec + 3 sec further exposure).
Once printed, thread the supports for the motor driver with an M3 tap and assemble the kit as follows:
TP4056
battery
driver
Use double sided tape to stick the motor to the top half of the casing.
