Hackaday.io Hackaday.io
Sign up Log in
SHARPIW0
SHARPIW0 : A RPI ZERO + 2.7" SHARP Memory display
pcadicpcadic
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
6 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
885
0
6
7
Team (1)
  • pcadicpcadic
Join this project's team
  • SHARPIW0 Carrier
ongoing project
raspberry sharp MemoryDisplay
This project was created on 12/15/2021 and last updated 5 years ago.
Starting from
Buy on Tindie
has orders / reviews
Ships from
Description
The SHARPIW0 carrier board has been designed to hold both a Raspberry(R) PI ZERO 2W or W + 2.7" (400x240) Sharp Memory Display. This display
The SHARPIW0 opensource carrier board has been designed to hold both a Raspberry(R) PI ZERO 2W or W + 2.7" (400x240) Sharp Memory Display. This display is capable of a fast refresh which allows the use of linux shells or display game images.
The board also has 4 independently controlable LEDs you can switch on/off with classic GPIO commands (C++ or Python)
The board also has 5 buttons you may also control via GPIO voltage detection (UP/Down voltage detection). You can use this board for gaming.
You purchase a fully assembled board (the RPI ZERO is not included) which has been tested working before leaving.
Project Logs
Collapse
  • RPI Games on 1b display
    pcadic • 12/27/2021 at 15:14 • 0 comments
    @fast_code_r_us
     made a cool port of a classic game under the device.
View project log
Log In/Sign up to comment
Sign up with Github
OR
Common Anode 6 x 7Segment display
Project Owner Contributor
6 x 7Segment Display
daves-dev-labDave's Dev Lab
A functioning replica of the TVA TemPad as seen in the Loki TV show.
Time Variance Authority TemPad
tanoTano
1.39" MIPI round display for STM32F769 Discovery Board
A Wearable MIPI display for STM32F769
yadayada
A matrix built from sixteen boards each containing eight - four character seven segment displays for a total of 4096 individual segments.
Number Matrix
seasleyeceseasleyece
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "SHARPIW0", please tell us the reason.
Send message
Remove Member
