ESPHome firmware for ESP32 with GGreg20_V3 – solution to the problem with the pulse counter
01/04/2025 at 11:57 • 0 commentsAt the end of December 2024, our user from Germany found that the pulse counter (pulse_counter component) in the example YAML code for ESPHome firmware with the ESP32 controller stopped working. Thank you, Kedalux, for paying attention to this and participating in the localization of the problem.
Read the full article at:
https://iot-devices.com.ua/en/esphome-esp32-ggreg20_v3-firmware-pulse-counter-issue-solution/
Technical note on initial diagnostics of the GGreg20_V3 Geiger counter with J305 tube
11/14/2024 at 19:13 • 0 commentsTechnical note on manual initial diagnostics of the GGreg20_V3 module with J305 tube to check the main module voltages at the control points and determine the module's operability
Read the full article:
https://iot-devices.com.ua/en/technical-note-on-initial-diagnostics-of-ggreg20-v3/
New GGreg20_V3 Review on Trustpilot
04/29/2024 at 07:07 • 0 commentsCD gave @IoT-devices, LLC, 5 stars on #GGreg20_V3 Ionizing Radiation Detector via Trustpilot
See the review at: https://trstp.lt/UbGwiXCh5
Geiger tube J305 conversion factor: differences between the coefficient for source radiation power and absorbed dose. Technical note
04/08/2024 at 06:58 • 0 commentsWe have previously written about how to calculate the coefficients for the SBM20 tube and the J305, tube that come with our Geiger counter module GGreg20_V3 for DIY / IoT projects.
However, in those articles, we focused heavily on the calculation formulas and almost overlooked a very important detail...Read the full article:
Technical note: How to calculate the conversion factor of CPM to μSv/h for DIY Geiger counter project with J305 GM-tube
03/26/2024 at 14:44 • 0 commentsWe have already made a similar publication for the SBM20 Geiger tube. This time we bring to your attention an article dedicated to the equally popular J305 GM-tube made in China.
Easy Link - bookmark or share:
Changes in ESPHome configuration validation – Pin Reuse validation
01/05/2024 at 17:01 • 0 commentsRecently, the ESPHome firmware has been changed to prevent the same controller I/O ports from being reused to create different entities.
These updates in ESPHome version 2023.12.0 also affected the examples developed by our company for the GGreg20_V3 Geiger counter ionizing radiation detector module.
According to the user’s request (https://github.com/iotdevicesdev/GGreg20_V3-ESP32-HomeAssistant-ESPHome/issues/2) regarding the repository for GGreg20_V3-ESP32-HomeAssistant-ESPHome, we have made the necessary updates to the configuration YAML file.
Now this example will work properly with the new ESHome configuration validation and you will be able to upgrade to newer versions of ESPHome without any problems.
We also plan to update other repositories with this issue.
Read the full article with examples and solutions here:
IF BlackFriday() OR CyberMonday() THEN Sale(%);
11/23/2023 at 19:16 • 0 commentsCyber Monday until 30.11!
![blackfriday cybermonday]()
We launch “Cyber Monday” campaign from 24.11 to 30.11 and set 10% discount when buying any of our modules on iot-devices.com.ua and Tindie and Etsy trading platforms.
Pay attention to our charity product GGreg20_ES
As well as our popular modules:
- GGreg20_V3 radioactive particle detector with J305 Geiger tube: ggreg20_v3
- DCDC_3V3_400V_V1 module is a high voltage 3.3V DC to 400V converter: dcdc_3v3_400v_v1.
- I2CUI4_V1 User Interface – I2C module with 5-button keypad: i2cui4_v1
Source:
https://iot-devices.com.ua/en/cyber-monday-promotion-till-30-11-en/
SBM20 GM-tubes are still available on Etsy to order with GGreg20_V3
11/19/2023 at 08:44 • 0 comments![]()
Hurry up if you want to order GGreg20_V3 with SBM20 tube.
Because our Tindie and website are out of these tubes (as of 11/19/2023), but they are still available on Etsy. At the same time, we also recommend ordering with J305, which is currently available in all stores.
Where to order with SBM20 or J305:
https://go.iot-devices.com.ua/ggreg20_v3_etsy
Or with J305 only:
- Tindie: https://go.iot-devices.com.ua/ggreg20_v3_tindie
- Website: https://go.iot-devices.com.ua/ggreg20_v3
Geiger counter GGreg20_V3 module is already on Etsy store
11/06/2023 at 21:58 • 0 commentsNovember 06, 2023, Kyiv, Ukraine.
Dear users, customers and partners!
We are pleased to announce that with the launch of Etsy Payments service in Ukraine, we immediately opened our own official store on this wonderful platform for DIY.
Now you can order the company’s products on Etsy or Tindie, as well as on our website. With the launch of Etsy Payments in Ukraine, our visitors and regular customers can choose any convenient and secure payment method such as bank cards, PayPal, etc. As an added bonus, Etsy protects transactions between consumers and traders within the platform.
Geiger counter GGreg20_V3 is also available for order in our Etsy shop!
Best regards,
Team IoT-devices
GGreg20_V3 and ESP12.OLED_V1 in the project of KPI specialists
08/22/2023 at 13:52 • 0 commentsAn interesting work by experts from the Kyiv Polytechnic Institute describes software methods for analyzing streaming data, in particular, for analyzing radiation pollution.
The article analyzes open data on radiation air pollution in the city Kyiv and visualized the data using analytical tools of the Python programming language.
Source:
https://iot-devices.com.ua/en/ggreg20_v3-esp12-oled_v1-kpi-project/
IoT-devices, LLC
