19.06.2022
06/19/2022 at 16:53 • 0 commentsI'm closing the Tektonika project because I got everything I wanted from it.
In parallel, he created a synthesizer project, the name of which has not yet been invented. It will be structurally based on Tektonika, but the management and technology have been heavily redesigned in order to get away from the "Kolhoz" (Collective farm).
My last steps in the project were pairing the levels of the Behringer mixer (which I treated cruelly) and trying to play the instrument)))
It turned out that it was necessary to work on eliminating the resonances of the diffusers and the structure.
The frame structure itself, which I invented, almost does not cause any complaints from me and will be used in the new project with almost no changes. -
21.05.2022
05/21/2022 at 17:30 • 0 commentsHaving once again taken up the alteration and examined the almost finished device, I thought that it looks like Kolkhoz (Collective Farm).
So they say in our places about something too DIY)))
I decided to make the upper part of a dark milled composite, into which to paste cards (yes, using the technology of bank cards and business cards) with the designations of the controls. The prototype was made at home on an inkjet printer and laminated with a matte film. -
23.04.2022
04/23/2022 at 16:14 • 0 commentsI made a reliable keyboard clamp and hung the synthesizer on the wall, to decorate which it was made :)))
10.04.2022
04/10/2022 at 14:10 • 0 commentsI will still adjust and ennoble the device, but you can post photos now)
All parts and blocks cost me about $600-700, while a proprietary workstation costs $2500-4000, it has a smaller display and one hard-wired software.
02.04.2022
04/02/2022 at 18:03 • 0 commentsToday I assembled the system in the most complete electronic configuration and played a little on the synthesizer)))
The surprise was the huge sensitivity of the power amplifier, I will think about what to do with it.
I had to turn all the controls down.
The experience of printing decorative elements in a photo studio turned out to be unsuccessful, I had to take out my printer, buy cartridges, regular and self-adhesive films, maybe I will also have to buy a laminator. Printing went well. -
20.03.2022
03/20/2022 at 13:47 • 0 commentsAlmost finished the left control panel, the photo gives an idea of how it should look like.
When printing self-adhesives (in a regular photo studio), they made a big mistake in size, although I output it in PDF.
The lamination doesn't work well...
Apparently, it is worth making the project collective, perhaps someone will make a drawing of the left panel for 3D printing.
I don't have this kind of design yet... -
08.03.2022
03/08/2022 at 05:45 • 0 commentsYesterday I painted the front decor of the mixer compartment. I will print in a printing house with lamination and self-adhesive underside.
I assembled the whole system to test the operation of the mixer from a USB hub and a USB OTG port. Soldered two cables - USB3.0 in an angular configuration, and USB OTG.
In general, the synthesizer, in breadboard form, works great, the mixing console works with both the hub and the USB OTG port)))
An unpleasant nuance came to light - when the hub is connected to the USB3.0 port of the tablet, the voltage of 5 volts goes to the 12 volt line, and feeds the power amplifier and everything else from the tablet!
I understood why. The current passes through the MOSFET protection diode of the pulsed DC/DC step-down powering the hub electronics.
It is necessary to put a Schottky diode in the 12 volt power supply circuit of the USB3.0 hub, for decoupling.
Thanks to the tablet and the hub for enduring! -
24.02.2022
02/24/2022 at 14:54 • 0 commentsAs work on the device crossed the equator, I began to think about the interface, microphone amplifier, headphones, mixing signals and switching it all.
It was also necessary to come up with a design.
All this made me sad until I suddenly realized that there are devices that combine these functions.
And called mixing consoles.
I quickly found a suitable model and I hope it will close my problems (except for happiness and money)))
Model and photo will be added in the next few minutes. -
20.02.2022
02/20/2022 at 08:29 • 0 commentsRevised the place of the power amplifier board.
Powered up the USB Hub and the tablet from "non-native" sources.
Unfortunately, I can allocate one day a week for these classes, the process is slow...
In addition, I tested the sound subsystem - speakers and D-class amplifier. Everything works, but the feeling of the predominance of medium and high frequencies.
In addition, the 13cm speakers are possibly redundant.
This is a consequence of the lack of a clear understanding of what the unit is made for - quiet home music making or playing at a noisy party))) -
13.02.2022
02/13/2022 at 13:35 • 0 commentsAt first, it was supposed to use the ACJS-MVD985-5 dual connector as audio connectors. However, this connector turned out to be quite rare and expensive. First of all, rare, I put up with the price)))
So now I put separate nests.
