camera_mounts.step
STEP file if you want to adapt the files for your components.
step -
292.12 kB -
03/18/2022 at 10:32
Download
motor_mount.3mf
Motor mount for standard FPV drone motors.
3mf -
196.52 kB -
03/18/2022 at 10:32
Download
wing_mount_A.3mf
Bottom part of the wing mount. It holds the nut and should be glued into the fuselage.
3mf -
4.66 kB -
03/18/2022 at 10:32
Download
wing_mount_B.3mf
Serves as a guide rail for the nylon screw.
3mf -
48.32 kB -
03/18/2022 at 10:32
Download
canopy_hinge_A.3mf
Canopy part of the hinge mechanism.
3mf -
12.59 kB -
03/18/2022 at 10:32
Download
canopy_hinge_B.3mf
Fuselage part of the hinge mechanism.
3mf -
9.53 kB -
03/18/2022 at 10:32
Download
fpv_camera_mount.3mf
Bottom facing FPV camera mount, fits the Cadx EOS2.
3mf -
34.26 kB -
03/18/2022 at 10:32
Download
elevator_horn.3mf
Bigger elevator servo horn for extra rigidity.
3mf -
8.48 kB -
03/18/2022 at 10:32
Download
battery_connector_holder.3mf
Simplifies the battery swaps.
3mf -
13.00 kB -
03/18/2022 at 10:32
Download
battery_terminal_clip.3mf
Extra precaution to prevent the Li-Ion cells from short circuiting.
3mf -
9.26 kB -
03/18/2022 at 10:32
Download
battery data.xlsx
Excel sheet with information about Li-Ion cells and calculations for flight time, range and speed.
sheet -
28.81 kB -
01/27/2022 at 18:45
Download
static thrust data.xlsx
Raw static thrust and power data for all the tests I’ve made.
sheet -
71.11 kB -
01/26/2022 at 18:04
Download
Articles on components.txt
Further articles and information on components.
plain -
603.00 bytes -
01/23/2022 at 16:27
Download
image sources.txt
plain -
462.00 bytes -
01/22/2022 at 11:49
Download
