Radial UVC Laser Barrier Against Bio-Hazards
Radial UVC laser barrier against viruses/bacteria/myceliums' spores with PIR motion/proximity sensor to safeguard users' tissues/eyesight.
3737
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
This product design is released as free public knowledge.
The idea behind it is pretty straightforward. It takes advantage of Brownian motion and natural convection to deactivate biological hazards like active viruses/bacteria/myceliums' spores.
It works by radially spreading a collimated ray of light thanks to a cylindrical glass. Due to the costs of EUV-UVX-UVC lasers, ideally, the glass has to be coated with a band-pass filter, to emit radiation frequencies ranging from 254nm to 261nm (the best at damaging DNA/RNA). By doing so, cheap laser sources with a noisy spectrum can be used.
Preferably, 4 are needed for a door. FFC/FPC wiring is the ideal solution to transfer energy to the device if wired. Wireless power could be an alternative. Doors' frames are a mere example;a spiraling tube that's traversed by the barrier can cross it many times.
Possible applications include door frames, room separators, transportation, farming, space, air filtering, water treatment.
