Default Setup:
RomWBW Setup:
Colecovision Setup:
MSX1 Setup:
MSX2+ Setup:
Terminal Demonstration:
With AY3-8910 Soundboard:
With SN76489 Soundboard:
I am proud to say that this project is sponsored by PCBWay.
A project initially based on Grant Searle's "CP/M on breadboard" and heavily inspired by RC2014
After all, I had to create a set of boards to clone my beloved first Sinclair ZX81 computer. Using the Baffa-2's CPU and Dual Clock board, it is possible to add 3 more boards to provide 32KB Ram/Rom, Keyboard and Cassette and Video I/O to build a ZX81 Clone.
For more information, More info: https://hackaday.io/project/188406-baffa-81-zx81-compatible-computer
In this photo, the Baffa-81 is using the new Baffa-2 backplane lite which has only 6 slots (original has 12 slots). This option was created because it is cheaper and can be used on smaller sets of boards.
Baffa-81 is a Sinclar ZX81 clone on Baffa-2 Homebrew Computer. It's based on Grant Searle's ZX80/81 Project and Wilco's ZX80/81 board. Also, the ps/2 interface is based on Danjovic's Tek v2 project.
All boards have arrived! Now I need to have some time to assemble and test them. I would like to thank PCBWay again for all their support on the Baffa-2 project. In addition to the boards being great (excellent quality), manufacturing and delivery are very fast.
Projected boards:
I had also created a reduced version of my backplane to reduce costs of this project :) . It's half the original backplane with only 6 slots. Can be connected to others via expansion port.
To complete the setup, it is necessary to use the Z80 CPU board and the dual clock board.
Baffa-X is a project to transform Baffa-2 into a MSX1 Computer. It's based on Brazilian Sharp's HB-8000 (Hotbit) schematics and Beer 202 IDE Board. The projects also uses the original Z80 CPU, 64KB RAM and TMS9918 Boards from Baffa-2.
For more information check Baffa-X project page
I've just tested a new set of boards for using the 6502 CPU. The project is slightly inspired by the RC6502 and I believe it may collaborate with it in the future. Initially it is a simple 6502 computer that is capable of running the Apple-1 rom but it should evolve soon.
Baffa-6502 is a subproject of Baffa-2 to create a new series of boards around the 6502 CPU architecture. This allows a new group of retro computers to explore in my project.
The first "setup" is an Apple -1 that runs Atari 2600 games (like CP/M that runs Colecovision) and is still in development. For now, I was able to test the new Atari 2600 card for the Baffa-6502 (Codename "Baffatari" 2600)
More info: http://baffa-6502.baffasoft.com.br and https://baffatari.baffasoft.com.br/
Baffa-X is a project to turn Baffa-2 into a MSX1 Computer. It's based on Brazilian Sharp's HB-8000 (Hotbit) schematics and Beer 202 IDE Board. The projects also uses original Z80 CPU, 64KB RAM and TMS9918 Boards from Baffa-2 and will be available soon.
More info at Baffa-X (MSX) Project
Well, it's not an emulation because it uses the same real components but the answer is yes, sure!
ZX81 set was designed last march and were the first boards I designed for Baffa-2 architecture but I prioritized other computers 'cos I assembled a ZX81 before this project. That will probably be the next set of boards I'm going to order and assemble... (check this out https://baffa-2.baffasoft.com.br/whatsnew.php)
ZX Spectrum I haven't been studying yet but is possible after have my ZX81 running. Even commodore 64 later since I've been working with 6502 CPU as well. For now, I'm studying the schematics from Apple ][+ computer and would be nice if I could design boards for it. In Brazil (where I live) the most common computers in 80s were Apple][+(and IIe), ZX81/ZX Spectrum and MSX (the most popular).
Great! Looking forward to see your boards for the ZX81 (that was my first computer). I still remember how amazed I was when I found out the ROM programmer was using a single IC, the Z80A, for both the ZXBASIC and for composing the video output signal. Keep up the good work.
Can this emulate the ZX81 or ZX Spectrum? That would be very interesting.
