NeoDigito are the alternative for conventional seven-segment displays and LED matrix, mainly for big size displays. With the advantage of having a better appearance and being easy to use, as they are built with the WS2812B controller, used in LED strips, which works with a single pin, making fun to display numbers, text and colors. You can give a distinctive look to your projects, regardless you are a maker or a professional.
The idea was born in a project that needed to show a lot of numbers and the capability to change colors depending on the value. This is our Open Source solution and we want to share it with you.
