Soda Bottle Display
huge Modular LED Display made from empty soda bottles
We will build a modular and scalable LED Display made from Club Mate bottles and boxes.
The first prototype will consist of 840 bottles in an array of 6x7 boxes (30x28 Pixel) .
To build it, we have to do many (at least 840) repetitions of monotonous working steps. Because we do not like tedious work it will be necessary to develop efficient production processes and tools.
The Idea is to use illuminated bottles as pixels, more precise the bottoms of the bottles. To use the bottles as pixels, we will wrap them into aluminium foil and attach one RGB or RGBW into each bottleneck. When you put the prapared bottles back to their boxes and tilt the boxes by 90 degree, you will look at an array of 4x5 bottle bottoms. If you prepare more than one box, you can arrange them to a display.
The idea for this kind of display is not new, during this project we will develop, document and share our own approach.
LED-Socket 20190523.7z
x-7z-compressed - 90.73 kB - 05/23/2019 at 12:42
Download
  • 840 × Club Mate Bottles
  • 42 × Club Mate Boxes
  • 840 × WS2812b on 10mm PCB
  • 840 × 3D printed LED sockets
  • 840 × Bolts for thermoplastics 3x10
View all 8 components
  • 1st test of the display
    Cadmium07/23/2019 at 08:23 0 comments
    As announced, we made a short videoclip of the working display. It was made during the first test at the c3RE Sommerfest.
  • Current state of the project
    Cadmium07/21/2019 at 07:39 0 comments
    After working hard for two month, we got the display working for the first time. The mechanical part was tedious but easy done.
    The electronic part was a bit complicated. We ran into problems with the control of the pixels, because we used WS2812 from different suppliers. We used LEDs on white PCBs and LEDs on black PCBs. It seems that there is a issue with the timing, we found out that we are not the only ones which ran into trouble with using the two types of LEDs together: https://www.geekabit.nl/projects/wedding-gift-sprite/ (section testing and debugging). We fixed the problem by using only the WS2812 mounted on white PCBs.
    The power supply is not finished, for the moment we are using four ATX power supplies.
    Also the mechanical structure is not finished. For now we attached the single boxes to a wooden structure with cable ties:
    So, the display is not finished but to watch the working display it is very impressive if you stand in front of it.
    A short video clip will follow.
  • First public demo
    DevTown07/16/2019 at 13:10 0 comments
    The display is still not finished, but we got it working for first time at the at the c3RE Sommerfest 2019. Here are some pictures:
  • Printing parts
    DevTown07/16/2019 at 13:09 0 comments
  • Wrapping bottles in aluminium foil
    Cadmium04/28/2019 at 11:32 0 comments
    After cleaning the bottles and removing the labels, we have to wrap them in aluminium foil ...840 times...
    First we have to cut 840 sheets of foil. We decided to use aluminium foil with a width of 30cm, which is enough to wrap the foil about 1.4 times around the bottle. If you use foil with a larger width, you will waste a lot of foil or, more important, you have to make two cuts instead of one for every sheet.
    We identified that the lenght of each sheet should be around 23cm. Because we do not have to mess with tight tolerances, it is possible to use a very simple tool to cut several sheets at once.
    The idea is to wrap several layers of aluminium foil around a core with a perimeter of 23cm and cut all layers at once.
    To realize this idea we used two pices of MDF with a thickness of 3mm and a height of 109mm. The width of the MDF parts should be at least the width of the aluminium foil. We used pices with a width 450mm.
    First, join the two pices by making a hinge with some kind of tape on the long edge of the pices.
    Then, add some kind of spacer inside the tool. We used thin wire which was taped to one MDF part.
    Finished!
    To produce the sheets, place the aluminium coil on a roller. We used a plastic box and a pice of tube. Clamp the start of the coil with the tool (this is the reason for using two times 3mm MDF with a hinge instead of a single 6mm MDF pice). Now you can start to wind the aluminium foil around the tool.
    After several windings (up to 15 are really good feasible) cut the aluminium foil.
    Voila! Several sheets with a lenght of nearly 23cm at once. Use the foil to wrap the bottles and secure the wrapped foil with some kind of adhesive tape (not shown in the pictures).
    We learned that one cutting-person can easily supply the aluminium sheets for two wrapping-persons just in time.
  • Assembling the LED sockets
    Cadmium04/22/2019 at 14:29 0 comments
    I tried to create a simple as possible solution to attach LEDs (presoldered strings) into bottlenecks. If you do not use presoldered LED-strings, there might be less complicated ways to mount the LEDs into the bottles.
    1. Mark the Dout side of the LED PCB (optional):
    2. Feed the LED through the base plate:
    3. Place the PCB on the wedge, the Dout side must face to the two little fins:
    and bend the wires around the wedge
    Insert the wedge into the baseplate:
    Now push on the cap and lock the wedge with a bolt (for thermoplastics 3x10). Note the form of the baseplate, it matches to the counterpart in one direction only!
    Finally, snap the socket to the sodabottle. Optional fasten the cap wit a 4.8mm cable tie.
  • Realizing the Dimensions
    Cadmium04/22/2019 at 12:23 0 comments
    In the past I collected 40 Boxes of Club Mate. This weekend I cleaned the bottles. While removing the labels and washing up the bottles, I became aware of the forthcoming work.
    The empty boxes:
    The final Display will look something like that (2 boxes missing):
    The Dimensions will be 240cm x 210cm
    The remains:
View all 7 project logs
  • 1
    Collect and clean 840 bottles of Club Mate
  • 2
    Print the LED sockets
  • 3
    Wrap aluminium foil around every bottle
    Do not cover the bottom of the bottles with aluminium foil
View all 3 instructions
[deleted]
DevTown wrote 09/17/2019 at 20:00 point
there could be a little problem with full bottles ...
weight ;-)
transporting empty ones is a lot more convenient.
Mike Szczys wrote 04/22/2019 at 14:44 point
Wow those sockets look really good. Will make alignment really simple.
That's a ton of soldering and assembly work. How many people do you have helping?
Cadmium wrote 04/23/2019 at 15:10 point
Hello Mike, thank you for the comment. I hope that our team will have at least a dozen helping hands.
