Done before I know...
With more people starting to follow this project, i guess it's time to start improving and rebuilding parts ;)
I think this unit has reached it's bodge limit, so i will probably need to go with a whole new version. This time i'll use a plastic support (less chance of severing a finger while it's running), powering the display without having to spin the battery, and either getting the images to the display by sd card, or some kind of serial data link. If i feel brave enough to do the extra fiddly soldering i might even use surface mount parts to minimise the visible circuitry.
This is really cool. Do you think you could try turning it into a Kerbal Space Program NavBall? I'm sure the KSP community would go nuts for it, being so much cheaper than mechanical alternatives.
Interesting idea, if I can get a reliable signal to the spinning globe I don't see any reason why not. Hopefully V2 will be a bit more compact, maybe with a smaller, lighter ring so it's not so dangerous ;)
I found this today -- you might like it:
Apparently there are such thing as 'spherical displays' that use fancy lenses and projectors and a sphere is of diffusing glass. I think this might be a little more feasable though...
Looking forward to mark 2!
How did you do the wiring to the spinning part? Your PIC and power source is outside the sphere, right?
