A USB-C connector on a flex PCB
Let's use an ATtiny84A as a structural element!
The plastic tab inside a USB-C port is about 0.7mm thick. Turns out you can make a cursed USB-C port by attaching a 0.6mm tall ATtiny84A (in the BGA package) to a flex PCB.
This is part of an ongoing series of projects involving creative interpretations of the USB mechanical standards. You've probably seen 2.0mm thick PCBs that fit in USB ports, and maybe you've seen 0.6mm thick PCBs that fit in USB-Micro cables. So what about USB-C? The plastic tab inside a USB-C port is about 0.7mm thick. I think [bobricius] has had success using 0.8mm thick PCBs; 0.6mm thick PCBs are way too loose. I haven't found a fab that will do 0.7mm (or 28 mil) PCBs unless you special-order an entire panel.
So, what other ways are there to reach 0.7mm thickness? My original plan was to join an 0.1mm flex PCB and an 0.6mm FR4 PCB, but then I realized: you know what else is 0.6mm thick? The ATtiny84A BGA package. Granted, there are only contacts on one side of the PCB, but that shouldn't matter with the symmetric USB-C pinout, right? ...Right? (foreshadowing)
The 3mm-square ATtiny acts as a stiffener for the flex PCB, and it comes out to 0.7mm on the dot! I only have an imperial set of calipers as seen above. The dial shows 0.0275 inches, which is 0.6985 millimeters. This looked promising as a cursed connector! I discuss it further in this project log. But, moving forward, there is a major change: switching to a folded-over PCB.
From a structural standpoint, I think this is going to work based on these designs I tweeted about.
With OSH Park flex, this results in a connector that's approximately 0.9 mm thick. Other vendors default to thinner polyimide substrates, which would get this back to 0.7mm. But honestly I'm not concerned anymore with adhering to the 0.7mm thickness; if I'm making unsanctioned USB connectors, may as well go all-in!
  • Origami time
    Sam Ettinger • 02/06/2022 at 17:44 • 0 comments
    On 2-2-2022, I established that I don't need 2 PCBs. I just need one that folds.
    I knew I wanted to try sandwiching an ATtiny84A between two flex PCBs, but before this I had been envisioning two disconnected PCBs, held in place with some structural solder or something along those lines. But then I saw this cursed connector by Joey Castillo, which got me thinking about a folding connector instead. Joey got it to work for a single-sided 5-trace Micro-USB connector, would it work for a two-sided 24-trace USB-C connector?
    I'm delighted to say that the folded flex USB-C works. For this demo I didn't want to use one of my precious BGA chips, so I went with a hand-solder-friendly ATtiny85 circuit like the Nanite or Digistump uses.
    Of course, using two flex PCBs adds some thickness. With OSH Park flex PCBs, an ATtiny84A sandwich would be around 0.9mm thick. Other vendors default to thinner substrates, but their prices are significantly higher for wee PCBs like mine. Anyway, I'm no longer adhering to the 0.7mm thickness requirement, let's get weird 😎
  • The single-sided boards that I tried (and don't plan to pursue further)
    Sam Ettinger • 02/06/2022 at 05:43 • 0 comments
    I realize now that a lot of the content I'd put in the "Project Details" section gets rapidly obsoleted, so I should be putting it in project logs instead. For example, the four demonstration projects that I described are no longer the ones I care about—I got one of them to 67% functionality and learned enough in the process that it wasn't worth pursuing the other designs. Here is some info about those designs, which originally was in the "Project Details" section.
    Demo 1: RGB LED that can't be programmed over USB
    When initially assembled, that 8-row FFC connector serves as a handy way to program the microcontroller. Once programmed, the connector can be sliced off; the remaining part fits snugly inside a USB-C cable. An RGB LED pokes out of the end, along with a tab that lets you pull the PCB back out again. Out of spite for, uh, myself, I have labelled that the "cowards' tab," encouraging myself to remove the tab and make the board impossible to extract. This would reduce a useful cable into little more than a soothing blinking light for all eternity.
    In a twitter thread, I documented the process of assembling this board. It was very fun! I learned that a layer of conformal coating was not sufficient to cover the components—the contacts in the USB-C cable quickly scraped away the coating and consequently led to shorts and burnt-out LEDs. I also learned that gently pulsing green and blue (as opposed to red green and blue) looked extremely soothing, so I felt less bad about abandoning the red channel in future designs.
    Even if the conformal coating had worked, the layout created its own issues. I should have controlled the RGB LEDs using the OCR0A/OCR0B/OCR1A/OCR1B pins for easy PWM adjustment. Instead, I had to resort to binary code modulation to achieve any sort of brightness control. It's working alright, as shown here (and further down that thread). And honestly it's a good excuse to play with binary code modulation, it's fun!
    Demo 2: RGB LED that can be programmed over USB
    It would be nice to use the USB data lines to program the microcontroller! I didn't attempt this for the Demo 1 because I wanted to keep the board as uncluttered and simple as possible. When I started routing this, I didn't find a way to connect all three LED channels, so I've elected to give it green-and-blue LED control only.
    All that's required are five extra components: a pullup for the D- line, small resistors on the D- and D+ lines, and zener diodes as level shifters. This is the low-complexity approach used on the Digispark and its derivatives. I have not attempted to make this board yet. Also, look at the 3d render above; doesn't it look like an owl? I love it.
    There is an interesting issue with the USB communication. In the USB-C standard, the D+/D- lines are only connected on one side of the plug! It assumes that the USB-C port has D+/D- connectors on both sides, so the plug orientation should not matter. But our USB-C port only has D+/D- connectors on one side. We've reintroduced the classic USB behavior of having to flip the device over 3 times before it works!
    Demo 3: Basically a Digispark
    In this version, the FFC portion is meant to stay attached! And all the components are 0402-sized with generous spacing so I can worry less when soldering. As a result it can be used in a slightly more "normal" fashion—still operable by sticking it inside a USB-C cable, but now there's a breakout of sorts.
    Demo 4: "Coulda used a 555"
    In the past I've poked fun at the "coulda used a 555" refrain by, among other things, using three microcontrollers where a 555 would suffice, and using a 555 Schmitt Trigger where a single SPST button would suffice. As luck would have it, there is a BGA 555 IC that is just shy of 0.6mm tall! I've had to pair it with a 10μF capacitor that is a bit taller, but it's a fun idea to explore later.
  • Repo updated!
    Sam Ettinger • 01/20/2022 at 01:14 • 0 comments
    I've finally gone and pushed some updates to the git repo. Demo 2, the one that's programmable over USB, was not in the repo until now; this is because I completely forgot I hadn't routed the PCB before I published the project! When I did start routing, I didn't find a way to connect all three LED channels, so I've elected to give it green-and-blue LED control only.
    In addition, I've added a fourth demo, which uses two 555 BGA ICs instead of an ATtiny84A. This is thanks to some "Coulda used a 555" comments on the post that made the Hackaday blog. Sadly I couldn't get those boards in time to enter the 555 contest, but it's still worth a go I think.
    I have a few ideas for how to address the short-circuit problems I encountered with the PCB I assembled previously. The obvious solution is to slap another flex PCB on top, which will create a double-sided USB connector. However, that would end up being about 0.85mm thick, which I worry would cause too much downward scraping force on the flex PCBs. There are vendors with thinner polyimide substrates, which I will look into.
  • Some updates
    Sam Ettinger • 01/01/2022 at 19:38 • 0 comments
    I failed to maintain a Single Source of Truth for this project—there's this HaD.io project, the git repo, and a twitter thread. The twitter thread has newer details than the other two, so here's are the highlights!
    After the thread started getting attention, I went ahead and just cut the flex connector off, thereby locking in the code that was on the ATtiny84A at the time. It did nothing when I put it in a USB-C cable connected to a wall wart, I have not tried plugging it directly into a computer at this time. But I did jury-rig a power-only setup using a micro-USB breakout and a USB-C breakout. Red and blue worked, but then something crackled and damaged the red and green LEDs. I know, right? What a surprise, pushing the exposed components against long parallel rows of conductive fingers caused problems! So I soldered a new LED on and applied two layers of conformal coating. That worked great for the duration of one tweet, then red stopped working. The conformal coating that I have is not strong enough to resist the scraping motions of the USB contacts, apparently. But I was left with a very pleasant blue-and-green doodad, which was fine by me. That was a good stopping place and I haven't had the chance to go back to it since then.
    I've since measured the OSH Park PCB to be closer to 0.2 mm (8 mil), thicker than I imagined. This makes it a bit harder to do what I want to do next, which is a """proper""" double-sided port made of two flex PCBs sandwiched around a microcontroller. If the current setup is 0.7mm, putting another 0.2mm board on top will be way too thick. Two possible things to try:
    1. an even shorter microcontroller. Do you know of one? The ATtiny20 in WLCSP-12 is at most 0.53 mm tall, are there any other options out there?
    2. cut a hole in the second flex PCB so the microcontroller can poke through but the other components are shielded. This needs a diagram to illustrate what I mean, I think, but I can't make one at the moment.
View all 4 project logs
Andrew Peters wrote 01/01/2022 at 21:53 • point
Do you think this could be used to hide microcontroller malware inside USB connectors? Are devices like these capable of transmitting data to an external IP address?
Sam Ettinger wrote 01/02/2022 at 22:19 • point
It could be possible, perhaps, with custom silicon and specialized tooling, but with flex PCBs and off-the-shelf ICs I think it would be extremely conspicuous! Maybe the makers of the o.MG cable would know what to do, but not me.
