1Arduino IDE board installation
Add this following line to the "Additional Board Manager URLs",
Then install Ameba D package from the board manager
Then select RTL8722DN(BW16) from "Board"
2Connect Ameba to the display and upload the code
Check here for the pin map,
and connect according to the code,
#define TFT_RESET PA27 #define TFT_DC PB3 #define TFT_CS PA15
also BL/LED to Vcc
SimonXi
