Flashing the bootloader worked. and at least the on-board Neopixel LED is working correctly
A project log for miniMetroM0
Ardruino Uno Mini crossed with Adafruit Metro M0 Express
There are programming pads for a Tag-Connect or compatible in the top right. With the help of the adapter from previous Log and a Atmel programmer (Atmel ICE in my case). Beside the wiring there is also this helpfull write up: https://learn.adafruit.com/how-to-program-samd-bootloaders
