Flashing Bootloader and first test
02/08/2022 at 19:34 • 2 commentsFlashing the bootloader worked. and at least the on-board Neopixel LED is working correctly
DIY Progarmming Adapter
02/07/2022 at 19:33 • 0 commentsI used a footprint compatible to Tag-Connect to program the SAMD21. This is only one time needed to burn the boot loader.
You could use the original our use a DIY attempt. There is alredy a DIY solution by Timon which you could find here: https://github.com/timonsku/oshconnect
This was partly my inspiration for my printed Adapter. I use the same Chinese pogo pins. I was just not happy about having an extra PCB there. The white part should be printable on most hobby SLA printers, although I used it to test JLCPCBs new printing service.
To this it is possible to older some cables and a little 10p SWD break outboard (thisor similar)
With this little board it easy to connect to your Programmer. I used an Atmel ICE for flashing the bootloader from the bigger Metro M0 Express.
Log for more Images
02/06/2022 at 21:00 • 0 commentsRendering of the back made in Kicad:
For refernce the first Tweet about this project.
02/06/2022 at 20:52 • 0 commentshttps://twitter.com/tinyledmatrix/status/1489645106323988483?s=20&t=bt-DCIdvQbnd1HggcUSvTQ
All Images should be also available here. There should be more Images and Information on this project side.
This Tweet predates this Project but was kind of the starting point
02/06/2022 at 20:47 • 0 comments
Alex
