1Install, Drivers and Customization
Getting wifi to work on A1466:
sudo apt-get install dkms bcmwl-kernel-source
Should fire up asap and works just fine.
Install Cinnamon Desktop:
https://tecadmin.net/install-cinnamon-on-ubuntu/
then select the Cinnamon Desktop at the password prompt during boot login. It will be set to default after that.
I also installed Adapta-Nokto as a theme for Cinnamon Desktop to make the window border style and task bar to my liking.
Swipe gestures:
https://github.com/Hikari9/comfortable-swipe
For some reason, the auto-start at boot feature doesn't work for me, so I added it to the autostart in Cinnamon by adding a custom command in System -> Preferences -> Startup Applications
comfortable-swipe startCustom boot screen:
https://www.xmodulo.com/change-boot-splash-screen-ubuntu-linux-mint.html
using https://www.gnome-look.org/s/Gnome/p/1009320
but the folders need to be changed in file: /usr/share/plymouth/themes/darwin/darwin.plymouth (because almost nothing in Linux ever actually works out of the box):
[Plymouth Theme] Name=Darwin OS X Plymouth Description=A Plymouth of OS X Yosemite ModuleName=script [script] ImageDir=/usr/share/plymouth/themes/darwin ScriptFile=/usr/share/plymouth/themes/darwin/darwin.scriptThen run:
sudo update-alternatives --install /usr/share/plymouth/themes/default.plymouth default.plymouth /usr/share/plymouth/themes/darwin/darwin.plymouth 100and then:
sudo update-alternatives --config default.plymouth
Select the theme you just installed via number and hit return.
Then regenerate the ram disk:
sudo update-initramfs -u
That's it.
Custom login screen:
https://github.com/PRATAP-KUMAR/ubuntu-gdm-set-background
Steam Games:
Yes, the MacBook Air can play games, even under Linux. To my surprise, even pretty well, at least 2D games. I remember using a steam-installer package but this one should work, too.
https://store.steampowered.com/about/
Alternatively, this:
https://www.codegrepper.com/code-examples/shell/how+to+install+steam+on+ubuntu+21.10
2Battle.Net - DOESN'T WORK
Just for testing, especially after Steam works so well with even 3D games, I wanted to see if I can get Diablo 2 Resurrected to work. So I went ahead and installed Battle.Net.
https://linuxconfig.org/how-to-install-battle-net-on-ubuntu-20-04-linux-desktop
However, the winetricks configuration didn't succeed as winetricks is outdated. Uninstall it and reinstall using a newer version using:
sudo apt-get remove winetricks wget https://raw.githubusercontent.com/Winetricks/winetricks/master/src/winetricks chmod +x winetricks sudo mv -v winetricks /usr/binaccording to https://askubuntu.com/questions/749549/winetricks-sha1sum-mismatch-rename-and-try-again
However, following those instructions didn't lead to anything usable, but this page offers some guidance to get the login screen to work:
https://github.com/lutris/docs/blob/master/Battle.Net.md
Specifically, go to settings before the launcher crashes on you, then Advanced settings, and deactivate hardware acceleration for browser content. That brought me at least into the main view and allows me to install Diablo. The download is currently running so I can't tell if it's gonna work, yet, or not.
EDIT: Wine and Battle.Net is horribly unstable. I won't be using it. I wasn't able to even install Diablo as the installer crashed four times because some sort of ad window popped up.
3Change Keyboard Mapping
After using the MacBook Air running Ubuntu for a few months, I can't help but notice that I'm not a fan of the keyboard layout. There are a few keys that need to be swapped for ease of use when running Ubuntu. Luckily, there is a very easy fix for that: https://github.com/free5lot/hid-apple-patched
Following those instructions and using the recommended keyboard remapping, the keyboard is now much more enjoyable.
4MacBook Pro 2016 without Touchbar Additions
Install audio drivers: https://github.com/davidjo/snd_hda_macbookpro
Install PulseEffects:
sudo apt install pulseeffects
Load my quick and dirty (not done yet) preset to make it sound better: https://cdn.hackaday.io/files/1833457844232480/MacBook%20Pro%202016%20No%20Touchbar.json
Install Bluetooth drivers: https://github.com/leifliddy/macbook12-bluetooth-driver
Install webcam driver (Does not work in Cheese but works in Zoom!): https://askubuntu.com/questions/990218/camera-not-working-on-macbook-pro
sudo apt-get install git sudo apt-get install curl xzcat cpio git clone https://github.com/patjak/facetimehd-firmware.git cd facetimehd-firmware make sudo make install cd .. sudo apt-get install kmod libssl-dev checkinstall git clone https://github.com/patjak/bcwc_pcie.git cd bcwc_pcie make sudo make install sudo depmod sudo modprobe -r bdc_pci sudo modprobe facetimehd sudo nano /etc/modules **add line "facetimehd", write out (ctl+o) & close**
For the module that is being built, I had issues. I can't really explain the problems well as I installed newer kernel sources than what Ubuntu comes with. I wasn't able to modprobe the firmware.bin file. After a few minutes, it just fixed itself and now it works.
I also haven't done the color calibration files: https://github.com/patjak/facetimehd/wiki/Extracting-the-sensor-calibration-files
Fix hibernation (seems to be an ongoing issue and I haven't tried this yet): https://github.com/Dunedan/mbp-2016-linux/issues/37
Hibernation on MBP2016 is a bit weird. Seemingly, the NVMe drive doesn't get out of suspension which means the file system either disappears or is suddenly read-only. To fix this, the following command can be used: https://github.com/Dunedan/mbp-2016-linux#suspend--hibernation
echo 0 > /sys/bus/pci/devices/0000\:01\:00.0/d3cold_allowed
However, running this manually each time the system boots is unacceptable. I also haven't tested the long term consequences of this or if it drains your battery faster.
It is better to run this using systemd at startup:
sudo su nano /usr/local/bin/fixMBP2016Suspend.sh
Add this to the file
#!/bin/bash echo "fixMBPSuspend: Adding fix to let MacBook Pro 2016 no touchbar wake up from suspend..." > /dev/kmsg echo 0 > /sys/bus/pci/devices/0000\:01\:00.0/d3cold_allowed
Save and exit.
Create another file
nano /etc/systemd/system/fix-MBP-Suspend.serviceAdd this to the file:
[Unit] After=network.target [Service] ExecStart=/usr/local/bin/fixMBP2016Suspend.sh [Install] WantedBy=default.targetSave and exit.
Add the proper permissions to both files:
sudo chmod 664 /etc/systemd/system/fix-MBP-Suspend.service sudo chmod 744 /usr/local/bin/fixMBP2016Suspend.shThen reload and initiate systemd with the new service.
sudo systemctl daemon-reload sudo systemctl enable fix-MBP-Suspend.serviceReboot and check dmesg to see if the script was run.
ps. this smmary for 2014 Macbooks is also very good: https://gist.github.com/johnjeffers/3006011ec7767a4101cdd118e8d64290
5Installing Windows on a Macbook Air 12" Retina
Check your MacBook version here: https://everymac.com/ultimate-mac-lookup/?search_keywords=a1534
Then use this information and this Driver Package Download Tool to download the right package for this MacBook: https://github.com/timsutton/brigadier
Then copy the contents of the download to the installer USB drive and use it if needed to load drivers for the SSD that might otherwise be hidden.
Timo Birnschein
