The sensor measures the change in the X and Y axis by taking multiple pictures and using its on-board DSP to determine the movement/change between them. It then stores the data in its memory which is accessed over SPI. The sensor can operate at up to 2000CPI and register acceleration up to 20G's
I have written a library to use with it that makes getting the X and Y movement pretty straight forward. I included some communication examples and the code and 3D models to make your own computer mouse.
DIY GUY Chris
chris.coulston
Nelson Phillips
Gentiam
HI everyone, I ordered enough parts for another production run so the sensor is back in stock. Thank you to everyone that bought it over the last two years and to anyone who buys it in the future!!
