Road stud based on 555 timer v1
Road stud based on 555 timer v2
Schema
In this project I used a 555 timer to create a road stud lights. the circuit contains on Ne555p timer, two LEDs, capacitor and some resistors. Also, I used a small solar panel to charge the battery and to detect whether it is day or night.
To charge the battery, I used the TP4056 ship, and I followed the given circuit example in the datasheet.
The used solar panel is a small solar panel with maximum output voltage of 2.5V. This solar panel is not suited for this application, since the TP4056 input voltage should be at least 4V. Hence, in the test circuit I built I did not include the TP4056.
The reset pin of the 555 timer is connected to the positive terminal of the solar cell through a transistor and pulled up using a 470 ohm resistor, in this way, the lights should flash during night, and turned off during day.
Nait Malek Youssef
cdvalenti
Wouter Minjauw
Open Green Energy
Dylan Bleier
